I purchased the VT-CC1110PA-433M RF Data Transceiver Module from DigiRF which has a CC1110 module embedded on it. The datasheet for CC1110 from Texas Instruments suggests there is an 8051 CPU inside the module as shown in the block diagram below:
I have an Easy8051 programmer from Mikroelektronika which uses the 8051Flash software as shown below:
I can't seem to figure out which 8051 microcontroller is embedded on the module. How do I program it? Or is CC-Debugger the only device that can program it?
