I have a problem with a battery booster/charger circuit, that I really can't figure out and I hope that somebody can help me.
This is the circuit:enter image description here
When i connect a 3,7V battery at X3-2 and X3-2 the TPS61200 quickly gets very hot. However it is still working and outputting 5V. At the moment the TPS output is not connected to anything.
There is no USB connected to the USB-POWER supply.
The circuit is based on the following schematic: http://cdn.sparkfun.com/datasheets/Prototyping/PowerCell-v13.pdf
Can anybody help me? Thanks!
UPDATE 1: I meassured the 5V output with an oscilloscope and got the following result: enter image description here It seems like the TPS cuts off repeatedly (maybe because of internal thermometer?). It cuts off at 5.8V, and drops down somewhere between 1-2V.
I also meassured while driving a DC motor and got a similar result: enter image description here
Here is the PCB-layout from eagle: Top enter image description here
Bottom enter image description here
I have also taken some pictures of the board: Top enter image description here
    \$\begingroup\$ How much current are you pulling (trying to pull) on the 5V? \$\endgroup\$ – Tyler Jul 25 '16 at 14:36
  • \$\begingroup\$ Can you provide a photo of the actual (built) circuit (possibly both sides of the PCB). Moreover, can you probe the 5V output with an oscilloscope? Maybe there is an high frequency oscillation superimposed to the 5V output. \$\endgroup\$ – Lorenzo Donati -- Codidact.com Jul 25 '16 at 15:03
  • \$\begingroup\$ How much copper is connected to the bottom-side exposed circuit pad of IC1? \$\endgroup\$ – Adam Lawrence Jul 25 '16 at 15:48
  • \$\begingroup\$ What inductor did you use? \$\endgroup\$ – Spehro Pefhany Jul 25 '16 at 15:57
    \$\begingroup\$ Is there any particular reason why the layout of your board differs so brutally from manufacturer's recommended layout? \$\endgroup\$ – Ale..chenski Aug 4 '16 at 1:14
In looking at your layout, you don't have a great thermal ground connection and are doubling your thermal resistance (Junction-to-board characterization parameter 16.8 C/W, if I read right which also happens to be the lowest thermal resistance pathway to the ambient) to the ground plane by halving the connections to it. And not having as much ground plane to sink current also presents an issue. The layout guideline in the datasheet has the ground connected on both sides. A quick look to the datasheet also suggests as well as other issues with this design:
If the layout is not carefully done, the regulator could show stability problems as well as EMI problems. Therefore, use wide and short traces for the main current path and for the power ground tracks. The input and output capacitor, as well as the inductor should be placed as close as possible to the IC. Use a common ground node for power ground and a different one for control ground to minimize the effects of ground noise. Connect these ground nodes at any place close to one of the ground pins of the IC.
It also looks like the inductor is located far away from the IC which probably isn't that big of a deal, but the cap C11 could be a big issue. You have a small trace from the battery to the power cap and from the power cap to the TPS61200, these traces have parasitic resistance and inductance. This parasitic impedance blocks the effectiveness of C11 and also makes it harder to source power from the battery at high frequencies. At this point I would consider scrapping this design and making it more like the manufacturers suggestion.
You could run through the power equations and throw in parasitic resistances and inductance and see what your biggest source of thermal error is. Simulating it in spice always helps too, and the parasitic resistances and inductances can be calculated from PCB trace calculators. One thing that you could do is beef up the traces to C11 with a blue wire and see if this helps on your current design.
Short story, follow the manufacturers lead on these, or do lots of math, but it usually takes less design time to just go with the manufacturers tested solution. Sometimes you can get away with layouts like this if your not generating a lot of heat in the switcher.
| improve this answer | |
