Does the RS-485 Standard include an error detection/correction scheme?
RS-232 has a parity bit for error detection, but I do not know anything related to error detection/correction in the RS-485 interface.
RS-485 and RS-232 a electrical-only standards. The same data encoding scheme is usually used on both. The difference is that RS-232 uses a single wire for the signal with levels below -5 V and above +5 V, while RS-485 uses a differential pair with 0-5 V levels. RS-485 is also intended to be multi-drop whereas RS-232 is point to point.
You can chose to use a parity bit, or not, on either physical layer.
In practice, parity bits are not used much since they give a poor level of protection for the number of bits spent. When reliability is important, chunks of data are usually wrapped in packets with more sophisticated checksums, then with a ACK/retry scheme at the level above the packets.
  • \$\begingroup\$ @Pipe: If I remember right, RS-232 is -5 to +5 volts minimum when sending, but a receiver must accept -3 to +3 V. \$\endgroup\$ – Olin Lathrop Jul 27 '16 at 12:42
RS-485 has several advantages over RS-232.
  • Multi-drop from one master to multiple slave nodes.
  • Differential signals for higher noise immunity.
  • Lower voltages means that a 5 V PSU can be used.
With the multi-drop facility it is necessary for the transmitter and receivers to be a little smarter than may be required for RS-232 communications as addressing has to be handled. Once a micro is involved it is not to difficult to add checksum calculations too.
The parity bits are a very crude protection and will detect a single or odd number of bit errors in a character. An even number of bit errors will go undetected. In contrast, a one-byte checksum has 256 possible values and the likelihood of an undetected error is far less. For additional security a two-byte, 16-bit checksum can be used.
No, that's up to the system designer.
For a recent question on the topic see How to calculate checksum by hand.
  • \$\begingroup\$ My absolute favourite here is Fletcher-16. It's trivial to calculate with the tiniest 8-bit micro if you have an add-with-carry (no expensive tables), while still offering close to the same protection as CRC-16. (Don't confuse this with Adler, who actually managed to mess it up) \$\endgroup\$ – pipe Jul 27 '16 at 13:24
  • \$\begingroup\$ Thanks, I've never come across Fletcher-16 before. Another one for the toolbox! \$\endgroup\$ – Transistor Jul 27 '16 at 13:30
  • \$\begingroup\$ I don't like 255 as a modulus, since every third byte only contributes a one-in-85 choice, every fifth byte a one-in-51 choice, every fifteenth byte a one-in-17 choice, and every seventeenth byte a one-in-15 choice. By contrast, in an Adler sum every byte contributes a one-in-251 choice. An alternative approach is to keep two running checksums and multiply one of them by 3 with each byte (so the second-to-last byte has a 3x contribution, the third-to-last byte has a 9x contribution, etc.) The pattern of contributions repeats every 64, but there are ways of dealing with that. \$\endgroup\$ – supercat Jul 27 '16 at 16:27
  • \$\begingroup\$ BTW, I think it's also important to note that--for better or for worse--Fletcher's checksum regards 00 and FF as identical. \$\endgroup\$ – supercat Jul 27 '16 at 16:30
