I want to generate a 10ms timer using ATMEGA32. The crystal used is 8MHz. Is this calculation correct TCNT0 value is correct.The prescaler value i used is 1024.
is the calculation and the value 78 for TCNT0 is correct?
    \$\begingroup\$ Seems correct to me. \$\endgroup\$ – Eugene Sh. Jul 27 '16 at 17:15
  • \$\begingroup\$ It is 0.000128 seconds not microseconds. But all the same, you have calculated TC as if it were 0.000128 seconds. \$\endgroup\$ – Bence Kaulics Jul 27 '16 at 18:19
If you want to get periodic timer, you shall use CTC mode.
Check the datasheet page 99:
http://www.atmel.com/Images/Atmel-7766-8-bit-AVR-ATmega16U4-32U4_Datasheet.pdf
The formula is: F = F_CPU / (2 * N * (1 + OCR0))
OCR0 = (F_CPU / (F * 2 * N)) - 1 = (8000000 /(100 * 2 * 1024)) - 1 = 38.06 = 38
Timer 0 CTC mode (page 106): WGM02=0 WGM01=1 WGM00=0
To use TIMER0_COMP_vect interrupt, OCF0 & OCIE0 flags must be set.
|improve this answer|||||
  • \$\begingroup\$ I was trying to implement delay without CTC mode \$\endgroup\$ – ganeshredcobra Jul 27 '16 at 18:07
  • \$\begingroup\$ Oh, then TCNT0 = F_CPU/N/F = 8000000/1024/100 = 78.125 = 78 so it is right. \$\endgroup\$ – Flanker Jul 27 '16 at 18:35
  • \$\begingroup\$ F_CPU/N/F what is that F which is substituted as 100? \$\endgroup\$ – ganeshredcobra Jul 28 '16 at 4:30
  • \$\begingroup\$ F is the timer frequency, if period is 10ms (0.01s) then 1/0.01=100Hz \$\endgroup\$ – Flanker Jul 28 '16 at 7:45
