I am using the PIC16F1619 microcontroller within the curiosity board, MPLAB IDE x and XC8 compiler. I am currently trying to get my board to read an analog value and then to transmit this value through a UART-USB ADM00559 breakout board, which uses the MCP2221 board.
I have read the datasheet and have set all associated registers that I can see and am currently trying to get the board to simply send any value, for example 'a' or 0x32 to the TX1REG register. I am using a program called 'Terminal' to see the incoming messages. I have set the Baud rate to 9600, data bits to 8, Parity to none, stop bits to 1, no handshaking. However currently I am getting just 0's out of the communication no matter what value I assign to the TX1REG
. Possible things of note/problems:
I've set the Tx pin to RC6, RC6PPS = 0x12, using the relevant PPS code and disabled the analog output functionality of as prescribed in the datasheet
I've set the SPxBRGH, SPxBRGL to a value of 52 according the 32MHz clock rate, this was done with SP1BRGH = 51 and SP1BRGL = 1, is this correct, or does it need to be some sort of equal pairing?
MAIN PROGRAM
[/code]
* File: ledblink.c
* Author: Patrick
* Created on July 24, 2016, 12:09 PM
#include <xc.h> // XC8 compiler header file
#include <stdlib.h>
#include <stdio.h>
#include "uart.h"
#define _XTAL_FREQ 32000000 // Define PIC16F1619 clock freq - 32MHz
// Above is header files - xc is for compiler, stdlib is for general function
//and stdio is for I/O. Below is the bit configuration
#pragma config FOSC = INTOSC // Oscillator Selection Bits
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON // MCLR Pin Function Select
#pragma config CP = OFF // Flash Program Memory Code Protection
#pragma config BOREN = ON // Brown-out Reset Enable
#pragma config CLKOUTEN = OFF // Clock Out Enable
#pragma config IESO = ON // Internal/External Switch Over
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable
// CONFIG2
#pragma config WRT = OFF // Flash Memory Self-Write Protection
#pragma config PPS1WAY = ON // Peripheral Pin Select one-way control
#pragma config ZCD = OFF // Zero Cross Detect Disable Bit
#pragma config PLLEN = ON // PLL Enable Bit (4x PLL is always enabled)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable
#pragma config BORV = LO // Brown-out Reset Voltage Selection
#pragma config LPBOR = OFF // Low-Power Brown Out Reset
#pragma config LVP = ON // Low-Voltage Programming Enable
// CONFIG3
#pragma config WDTCPS = WDTCPS1F// WDT Period Select (Software Control
#pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
#pragma config WDTCWS = WDTCWSSW// WDT Window Select
#pragma config WDTCCS = SWC // WDT Input Clock Selector
int result; //variable to store our ADC result
int main() {
TRISAbits.TRISA5 = 0; // Set pin as output for LED Flash
UART_Init(9600); // Call UART initialisation function
TRISCbits.TRISC6 = 0x00; // Set pin RC6 as output
TRISBbits.TRISB6 = 1;
//Main while loop
while(1)
TX1REG = 'a';
// UART_Write(PORTBbits.RB6);
// UART_Write('a');
LATAbits.LATA5 = 1; // Turn on the LED
__delay_us(10000);
LATAbits.LATA5 = 0; // Turn off the LED
__delay_us(10000);
return 0;
UART header file
char UART_Init(const long int baudrate)
ANSELCbits.ANSC6 = 0; // Disable Analog function of pin RC6/AN8
RC6PPS = 0x12; // Sets RC6 to PPS Transmit Serial Data
SP1BRGL = 0x32; // Initialising SPxBRGH & SPxBRGL register pair (BAUD)
SP1BRGH = 0x1; // Initialising SPxBRGH & SPxBRGL register pair (BAUD)
BRGH = 0; // Initialising BRGH and BRG16 register pair (BAUD RATE)
BRG16 = 0; // Initialising BRGH and BRG16 register pair (BAUD RATE)
SYNC = 0; // Clearing SYNC bit (TXxSTA reg)|Configures EUSART for asynchronous operation
SPEN = 1; // Enables EUSART and configures TX/CK I/O pin as output
TXEN = 1; // Enables Transmitter circuitry
char UART_TX_Empty()
return TRMT;
char UART_Data_Ready()
return RCIF;
char UART_Read()
while(!RCIF);
return RCREG;
void UART_Read_Text(char *Output, unsigned int length)
unsigned int i;
for(int i=0;i<length;i++)
Output[i] = UART_Read();
void UART_Write(char data)
while(!TRMT);
TX1REG = data;
void UART_Write_Text(char *text)
int i;
for(i=0;text[i]!='\0';i++)
UART_Write(text[i]);
