I'm new to model sim. I have this vhdl
-- Code your design here
library IEEE;
use IEEE.std_logic_1164.all;
entity my_and is
port(x : in std_logic; y : in std_logic; z : out std_logic);
end entity my_and;
architecture rtl of my_and is
begin
    z <= x and y;
end architecture rtl;
And this test bench
library IEEE;
entity my_tb is
end entity my_tb;
architecture rtl of my_tb is
    component my_and is
    end component my_and;
    signal clk : std_logic := '0';
    signal x : std_logic;
    signal y : std_logic;
    signal z : std_logic;
    constant period : time := 1 ns;
begin
    unit : my_and
        port map(x => x, y => y, z => z);
    clk_process : process
    begin
        clk <= '1';
        wait for period/2;
        clk <= '0';
        wait for period/2;
    end process clk_process;
    unit_proc : process(clk)
        variable count : integer := 0;
    begin
        if(clk'event and clk = '1') then
            if(count mod 4 = 0) then
                x <= '0';
                y <= '0';
            elsif(count mod 4 = 1) then
                x <= '1';
                y <= '0';
            elsif(count mod 4 = 2) then
                x <= '0';
                y <= '1';
            else
                x <= '1';
                y <= '1';
            end if;
        end if;
    count := count + 1;
    end process unit_proc;
I've written the test bench by my self, I haven't used the tool. However when I do "Simulation -> Run simulation" the console tell me
Error loading design
I've set the test bench as top entity. Is there something I could check in order to run the simulation?
In terms of what the console spit out, here's what I get:
Compile of my_and.vhd was successful.
# Compile of my_and_tb.vhd was successful.
# 2 compiles, 0 failed with no errors.
vsim -gui work.my_and(rtl)
# vsim
# Start time: 11:30:05 on Jul 28,2016
# Error loading design
    \$\begingroup\$ There should have been more errors before the Error loading design. Have a look in the log and messages windows. \$\endgroup\$
    – scary_jeff
    Jul 28, 2016 at 9:15
    \$\begingroup\$ The architecture name in end architecture arch; doesn't match the declared architecture name (rtl). Process unit_proc is missing a sensitivity list (clk). There's nothing that increments count. And there's nothing that sets the simulation duration (other than the implementation, e.g. run 10 ns). And count mod 2 = 2 is never true. Which also points out you should simply use values of count. Or you could use mod 4. You should insure count doesn't overflow. After fixing all that I get waveforms. Check those errors like scary_jeff suggests. \$\endgroup\$
    – user8352
    Jul 28, 2016 at 10:13
  • \$\begingroup\$ I fixed all you said, sorry for the silly mistakes. Still doesn't work. \$\endgroup\$ Jul 28, 2016 at 10:30
  • \$\begingroup\$ Looks like you're trying to simulate the gate,my_and not the testbench my_tb.. \$\endgroup\$
    – user16324
    Jul 28, 2016 at 11:40
  • \$\begingroup\$ Shouldn't my "my_tb.." be the top entity? \$\endgroup\$ Jul 28, 2016 at 12:10
If you have the student edition, make sure you have the license, and if you have the license, make sure youve copied it to the right folder
