I have a device with a 14.4V battery (a Roomba) and I wish to design a LiIon battery + charging system to replace the existing arrangement.
I would like to charge it with the standard charger that comes with the Roomba. The current battery box will take 8 - 18650 size cells.
My question is will a 4 cell, 14.4 V 4S Li-ion Lithium Battery 18650 Charger Protection Board 15A work to protect the batteries so I can use the standard charger that will provide 20 V to the charger protection board?
I was looking at using this: http://www.ebay.com/itm/321820489871?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Any ideas? Thanks!
closed as off-topic by laptop2d, Daniel Grillo, pipe, Sparky256, Bence Kaulics Jul 30 '16 at 13:02
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – laptop2d, Daniel Grillo, pipe, Sparky256, Bence Kaulics
If this question can be reworded to fit the rules in the help center, please edit the question.
Choose one - listed with highest probability first:
  • No
  • Not really
  • Not very well.
    Expect very short battery life.
    Or very very short.
  • Maybe for a while
  • Maybe
A protection board is intended to be used to protect the cells against extremes and excesses. It is not intended to be a charger UNLESS that functionality is specifically included.
The example board includes the word "charger" in the description in some places and not in others. The specifications do not indicate that charging is a major intention.
Charger ICs and charging PCBs and whole chargers, targeted at 4S charging are 'common enough'. Design or use one.
A protection circuit may not prevent overvoltage when charging, probably-won't terminate charging when Ichg falls to a preset fraction of Ichg_max, probably does not limit Ichg to a safe level and probably allows discharge to voltages which are damaging in repeated use.
