I appologise if this seems like a dumb question, but is it possible to get a Xilinx FPGA (specifically, the Artix-7 35T) to run Linux without the use of Xilinx's EDK? I have found some tutorials like this one but they seem to require the EDK (of which there is no free version I believe).
I am currently using Vivado and the Xilinx SDK and I can get a simple C "Hello World" program to run, but I am having problems with trying to get it to run Linux. Can I implement Linux using those two tools? Is there a good guide anywhere on how to do it?
  • \$\begingroup\$ Look at the Yocto system and the "meta-xilinx" layer. \$\endgroup\$ – pericynthion Sep 14 '16 at 6:38
@Blair Fonville is right, you can only run Linux on a Sofprocessor in FPGA. Microblaze can run Linux, http://www.wiki.xilinx.com/MicroBlaze. But I think it will need a significant number of logic resources for that, I am not sure whether this Artix can do that.
Have a look on Zynq chip from Xilinx. There are relatively inexpensive SBCs with Zynq which has dual Cortex A9 inside which can run Linux just fine.
| improve this answer | |
  • \$\begingroup\$ These two statements are contradicting themselves: "you can only run Linux on a Sofprocessor in FPGA" & "has dual Cortex A9 inside which can run Linux just fine".. \$\endgroup\$ – m.Alin Feb 17 '17 at 9:52
  • \$\begingroup\$ Nope, they are not. \$\endgroup\$ – zdun8 Feb 17 '17 at 13:09
  • \$\begingroup\$ AFAIK, Zynq is an FPGA with hard CPUs inside, right? \$\endgroup\$ – m.Alin Feb 17 '17 at 13:13
  • \$\begingroup\$ Yes, it's exactly as you said. \$\endgroup\$ – zdun8 Feb 19 '17 at 0:18
I don't know the chip details, but if the Artix supports microblaze soft cores then it will work fine. In Vivado, build the system as a block design (IP Integrator) and use SDK to build the kernel.
