I've got a circuit using two dual opamp ICs and one voltage reference (see schematic below). I have a dual supply and use one of the opamps to create a low noise negative reference. The other opamp IC uses these two references. I have a simple follower and a differential amplifier implemented in this second IC.
The problem is that the follower doesn't follow(??). Any ideas about why this isn't working? I'm pretty sure its not a wiring problem since its actually on a PCB created from the schematic below and I've checked it pretty thoroughly.
Edit:
A couple people noted some odd/wrong things with my schematic. The image above is sub-circuit pulled from the one shown below.
