I'm going to start a project on a controlling speaker array and I need to control the signal's polarity fed into each speaker. I want to make a 'router' or 'controller' to make it easy, so I don't have to change all the wiring when I want to change the polarity distribution.
I googled some keywords and found H-bridge IC. But I'm not sure if that is compatible with AC signal. Besides, I'm afraid of controller size, because I need the controller for speaker ARRAY including many speakers, at least 9.
So, anyone who has an idea how can I solve the problem would be appreciated, very much. Now I'm thinking about kind of multi-channel connector that I can assign the signal to each port. (e.g., (+) signal to 1,3 port and (-) signal to 2,4 port)
Thanks for reading, I'm waiting for the advice. Have a nice day!
  • \$\begingroup\$ H bridges are for DC corrent. It is not clear what you want to achieve. What about a small graph with waiveforms you have and you want to feed to the speaker ? \$\endgroup\$ – matzeri Jul 31 '16 at 5:41
  • \$\begingroup\$ @matzeri Thanks for a reply. I'm going to feed just sinusoidal signals to each speaker, but with different polarity(out-of-phase). So that they form a spatial distribution. Most simple case is dipole speaker, which has two speakers playing same signal, out-of-phase. I wanna extend this concept into 2-D array. \$\endgroup\$ – user6650258 Jul 31 '16 at 7:15
  • \$\begingroup\$ This could work if you only need to change the signals sometimes. You will have to modify slightly to power the relay from a separate supply but it will let you have just one relay per speaker to set and REMEMBER the polarity. - electronics.stackexchange.com/questions/146258/… \$\endgroup\$ – KalleMP Jul 31 '16 at 7:35
Just use a DPDT switch:
If you want to control this from a remote panel, you can use DPDT relays to do that.
| improve this answer | |
