I am simulating a project on Proteus simulation software using this microcontroller. My issue is, I have made a 2 sec interrupt on timer0. But simulation is showing it as tooo fast (w.r.t simulation clock).
I used the Mikroelectronica Timer calculator using these settings:
The simulation schematic is as follows:
I am using MikroC pro for PIC compiler. And yes, I have double-checked the Clock frequency in the compiler, of the quartz crystal and the MCU in proteus, all are 4 MHz. I have set the crystal as XT in the compiler as well.
What could be the reason behind this inaccurate timer?
The code I'm using is as shown below:
int toggle1 = 0;
int toggle2 = 0;
int toggle3 = 0;
int toggle4 = 0;
void InitTimer0(){
  T0CON  = 0x84;
  TMR0H  = 0x0B;
  TMR0L  = 0xDC;
  TMR0IF_bit = 0;
  TMR0IE_bit     = 1;
void Interrupt() {
  if (INT0IF_bit && INT0IE_bit) {
     INT0IF_bit = 0;
     if(toggle1 == 0){
          LATC0_bit = 1;
          LATC2_bit = 0;
          toggle1 = 1;
          INTEDG0_bit = 1;         // Interrupt on rising edge on RB0
     else{
          LATC0_bit = 0;
          toggle1 = 0;
          INTEDG0_bit = 0;         // Interrupt on falling edge on RB0
   if (INT2IF_bit && INT2IE_bit) {
     INT2IF_bit = 0;
     if(toggle2 == 0){
          LATC3_bit = 1;
          LATC2_bit = 0;
          toggle2 = 1;
          INTEDG2_bit = 1;         // Interrupt on rising edge on RB0
     else{
          LATC3_bit = 0;
          toggle2 = 0;
          INTEDG2_bit = 0;         // Interrupt on falling edge on RB0
   if (INT1IF_bit && INT1IE_bit) {
     INT1IF_bit = 0;
     if(toggle3 == 0){
          LATC0_bit = 1;
          LATC2_bit = 0;
          toggle3 = 1;
          INTEDG1_bit = 1;         // Interrupt on rising edge on RB0
     else{
          TMR0IE_bit     = 1;
          toggle3 = 0;
          INTEDG1_bit = 0;         // Interrupt on falling edge on RB0
          delay_ms(500);
          LATC0_bit = 0;
   if (TMR0IF_bit){
    TMR0H    = 0x0B;
    TMR0L    = 0xDC;
    if(toggle1 == 0 && toggle3 == 0)
          LATC2_bit = 0;
    if(toggle4 == 0){
         LATC4_bit = 1;
         toggle4 = 1;
    else{
         LATC4_bit = 0;
         toggle4 = 0;
void main() {
  ADCON1 = 0x07;           // All digital I/O
  RBPU_bit = 0;
  TRISB = 0xFF;            // Set PB0 as input
  TRISC = 0x00;            // Set PortD as output
  PORTC = 0x00;            // Starting value for PortD
  INTEDG1_bit = 0;         // Interrupt on falling edge on RB1
  INTEDG2_bit = 0;         // Interrupt on falling edge on RB2
  INT0IF_bit = 0;          // Clear INT0IF
  INT0IE_bit = 1;          // turn OFF interrupt on INT0
  INT1IF_bit = 0;          // Clear INT1IF
  INT1IE_bit = 1;          // turn OFF interrupt on INT1
  INT2IF_bit = 0;          // Clear INT2IF
  INT2IE_bit = 1;          // turn OFF interrupt on INT2
  InitTimer0();
  GIE_bit = 1;             // enable GIE
  while(1){}
  • \$\begingroup\$ Probably because you're not clearing the Timer0 Interrupt Flag in your interrupt handler. And on an unrelated note - why do you have a delay_ms() call inside your interrupt? That's begging for trouble... \$\endgroup\$
    – brhans
    Aug 1, 2016 at 23:31
  • \$\begingroup\$ Thank you that clears it. I know that delay shouldn't be there. My timers were not responding up till now, so that was a last resort. I will make a 500ms timer now for that delay purpose. Thank you! \$\endgroup\$ Aug 1, 2016 at 23:44
  • \$\begingroup\$ Can someone please upvote the question. I have another related to this project but can't ask it -.- \$\endgroup\$ Aug 3, 2016 at 10:08
You need to have a TMR0IF_bit = 0; otherwise your code will just stay stuck in the interrupt, repeating it over and over.
