I am interested in increasing the range of NFMI - near field magnetic inductions, used in hearing aids.
However the limiting factor is a range of 10cm, typically seen in hearing aids with a coil diameter of 1.5mm.
According to the magnetic field strength formula formula
According to the formula: A desired magnetic field intensity(B), can be achieved at an increased distance(r) of 100cm, with a radius(a) increase of 31.7 times the initial radius
Am I right in assuming this, or will there be practical problems/ unseen effects for such an antenna with large radius to work with magnetic induction of low frequencies such as 10MHz.
  • \$\begingroup\$ Is this for a standard loop hearing-aid system? Can you add a little more information in your original post to give some context. I have installed some loops for friend and he is very happy with the results. \$\endgroup\$ – Transistor Aug 2 '16 at 8:54
  • \$\begingroup\$ It's common to use transmitter antennas with a radius of 50m or more. The problem with increasing the sensitivity of the receiver is that you increase the sensitivity to noise. \$\endgroup\$ – david Aug 2 '16 at 10:24
Magnetic field falls with distance cubed so, if the distance is increased by 10:1 then the field has fallen by 1000:1.
On the other hand if the radius increases by \$\sqrt{1000}\$ then you receive the same magnetic flux density. For confirmation of your formula see this: -
Picture taken from hyperphysics website
| improve this answer | |
