What is the different between stochastic optimal control approach in finance and engineering? Why methodes used in finance approach like Ito calculus are not used in engineering?
closed as primarily opinion-based by Bence Kaulics, Daniel Grillo, Sparky256, efox29, laptop2d Aug 4 '16 at 18:29
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ As far as I remember, the stochastic runs on 12 V DC in engineering whereas in finance it runs on hunch. \$\endgroup\$ – Transistor Aug 2 '16 at 22:33
  • \$\begingroup\$ Engineering is much more predictable than Finance... that's mainly because people are part of the loop... if they were no people there would be better precision in the Finance predictions. but then there would be no Finance... \$\endgroup\$ – Spoon Aug 2 '16 at 23:11
  • \$\begingroup\$ Please see this for help on writing good questions: electronics.stackexchange.com/help/how-to-ask This is a non-specific question and creates discussion, this is a Q&A based site. The math is the same in finance and engineering, the terminology is different, the method of application is different. \$\endgroup\$ – laptop2d Aug 4 '16 at 18:28
My introductory answer is that engineering they does use those methods if the situation calls for it. First, the development and implementation of computers suitable for financial use (e.g. high frequency trading) is both a finance and engineering problem: financial engineering is a discipline.
In control systems we try to establish a general model that describes how the system works and that dictates what types of inputs our controller should be prepared to anticipate. Stock markets are better modeled by geometric Brownian motion, for which the Black-Scholes equation offers a solution. Many control problems in control systems engineering will involve some study of standard Brownian motion and Wiener processes. Brownian motion has a basis in physics.
The DSP Stack Exchange would probably give more insight answers, since that finance data and physical data are both just signals from the perspective of that field, and signal processing methods apply to them.
    \$\begingroup\$ Financial Engineering: both a career and a crime! \$\endgroup\$ – Daniel Aug 3 '16 at 5:39
  • \$\begingroup\$ @Daniel Yes, yes it is. \$\endgroup\$ – jbarlow Aug 3 '16 at 5:46
Generally engineering doesn't have to deal with stochastic processes.
Finance suffers the problem of a huge number of dependent inputs from everyone involved in an economy, which have to be handled stochastically. In engineering, generally the number of relevant input variables is small and can be managed with regular calculus.
The big area which does have to be treated stochastically is sensor filtering, for which the Kalman filter is usually used.
