I'm quite confused on what should be the typical tasks of a Design Verification Engineer in ASIC Design. In my experience these were the things that I do:
  • Create verification plan
  • Create testbench architecture plan
  • Build the testbench
  • Create the testcases
  • Run RTL regression to verify the DUT until coverage is 100%
  • Run GLS
Now, I don't know if the following are still the responsibility of the Design Verification Engineer:
  • Debug the RTL (Is this a task of the RTL Design Engineer?)
  • Linting (Is this a task of the RTL Design Engineer?)
  • LEC (Is this a task of the RTL Design Engineer?)
  • Synthesis (Is this a task of the RTL Design Engineer?)
  • STA (Is this a task of the PNR Engineer?)
  • Debug timing (Task of RTL Design Engineer or PNR Engineer?)
  • Generate SDF (Task of RTL Design Engineer or PNR Engineer?)
Thanks.
Your first guesses seem right. You would create and run testcases to verify functionality of the RTL.
For the other items, I have listed how I would classify them.
It will definitely vary between companies. But in general I would say:
  • Debug the RTL (RTL Design Engineer; Circuit Design Engineer if you want to try different implementation than how it was originally coded)
  • Linting (RTL Design Engineer, sometimes they pass off bad RTL, then it becomes Design Engineer's job)
  • LEC (Library Design Engineer on individual cells; RTL vs. Schematic is Circuit Design Engineer, RTL vs. RTL may be RTL Design Engineer) There are other equivalence tools as well such as symbolic which could be used.
  • Synthesis (Circuit Design Engineer on critical blocks; Physical Design Engineer at top level glue logic)
  • STA (Circuit Design Engineer on critical blocks; Physical Design Engineer at top level)
  • Debug timing (Library Design Engineer on individual cells; Circuit Design Engineer on critical blocks; Physical Design Engineer at top level)
  • Generate SDF (Library Design Engineer on individual cells; Circuit Design Engineer on critical blocks; Physical Design Engineer at top level)
Depending on how wild-west your company is you could do all of these!
  • \$\begingroup\$ Thanks for your comment. Yes, it looks like the task differs from company to company. Or sometimes from project to project. Anyway, the reason why I asked this is because in project management, it's better if there are division of labor to make tasks run in parallel. Although this might take more engineers for a project, it helps in reducing the time of finishing the project. \$\endgroup\$ – ReubenMijares Aug 3 '16 at 8:08
