I have written into a procedure the behavior of a simple SPI transaction that I use in my testbenches to make things easier to write and read. Is there a way to make this procedure as generic as possible by not mentioning the size of the vector data given as a parameter? Or maybe add a size parameter as an integer?
Here's the procedure I'm using so far. For now I have one procedure declaration for each vector size I want to transfer.
procedure spi_transfer_3B(data : std_logic_vector(23 downto 0)) is
variable bitCnt : integer := data'length-1;
begin
    spi_clk <= '0';
    spi_mosi <= 'Z';
    spi_ss <= '0';
    wait until rising_edge(clk);
    for i in 2*data'length-1 downto 0 loop
        wait for SPI_CLK_PERIOD/2;
        spi_clk <= not spi_clk;
        if spi_clk = '0' then
            spi_mosi <= data(bitCnt);
            bitCnt := bitCnt -1;
        end if;
    end loop;
    spi_clk <= '0';
    spi_ss <= '1';
    spi_mosi <= 'Z';
end spi_transfer_3B;
What do you think?
  • \$\begingroup\$ Have you tried removing the range specification in the first line and seeing if it works for different widths of data? \$\endgroup\$ – scary_jeff Aug 3 '16 at 9:45
  • \$\begingroup\$ Yes, it is somewhat working, but not really. spi_transfer(x"45") gives me "A2" after deserializing the MOSI line. But it is probably the way to go, I'm trying to find the tweaking needed here \$\endgroup\$ – Fluffy Aug 3 '16 at 9:58
  • \$\begingroup\$ Oh... 0x45 = 0b01000101 and 0xA2 = 0b10100010. It's inverted, okay \$\endgroup\$ – Fluffy Aug 3 '16 at 10:01
This seems to work. I was confused because not mentioning x downto x coded the vector LSB first instead of MSB first as intended in my first snippet of code. It is that easy.
procedure spi_transfer(data : std_logic_vector) is
variable bitCnt : integer := 0;
begin
    spi_clk <= '0';
    spi_mosi <= 'Z';
    spi_ss <= '0';
    for i in data'range loop
       spi_clk <= '1';
       spi_mosi <= data(i);
       spi_clk <= '0';
    end loop;
    spi_clk <= '0';
    spi_ss <= '1';
    spi_mosi <= 'Z';
end spi_transfer;
    \$\begingroup\$ You can simplify and eliminate bitCnt to i, by reversing the range of the loop for i in data'range loop ... (or reverse_range as appropriate), and a second wait and spi_clk assignment, instead of doubling the range and using the if statement. \$\endgroup\$ – user_1818839 Aug 3 '16 at 10:54
  • \$\begingroup\$ Good call, it looks better this way. I'm editing my answer with your simplification. Thanks! \$\endgroup\$ – Fluffy Aug 3 '16 at 12:52
  • \$\begingroup\$ .... closer ... but now you can (and probably must!) eliminate the "if" too, and you can explicitly set spi_clk to '0' or '1' in each assignment. \$\endgroup\$ – user_1818839 Aug 3 '16 at 13:40
    \$\begingroup\$ Edited again, thanks! I didn't read your first comment carefully enough, my bad \$\endgroup\$ – Fluffy Aug 3 '16 at 13:49
