The PMBus specification (>= Rev1) specifies that the query command returns a data byte with a binary bit pattern of 001 in bits 4:2 if the format used for the queried command is a "16 bit signed number".
this is the only mention I can find of this data format (distinct from other 16 bit formats already covered by other bit patterns) within the PMBus standard.
What does this relate to? (AVS maybe?) Am I missing something silly?
*Note that I come at this from the device designer side rather than the host system side
This is just a 2's complement signed integer, as I believe.
  • \$\begingroup\$ Did you mean that this is a format made available for manufacturers to use as they wish? (I mean I know what a 16 bit unsigned integer consists of :D) But there are no specification defined commands mentioned that use it or any other mention of it in the spec at all \$\endgroup\$
    – Toby
    Aug 5 '16 at 8:16
  • \$\begingroup\$ @Toby, no, I mean this just is the most widely used signed integer format. Please see en.wikipedia.org/wiki/Two%27s_complement. \$\endgroup\$
    – Mark
    Aug 5 '16 at 9:05
  • \$\begingroup\$ Well this I know. I am asking sepcifically in the context of the PMBus specification however. All other formats used within this spec have information on where they are used, with which commands, etc. Conversely this format doesn't actually appear to be used! Thus my confusion in how it is included in the QUERY command. \$\endgroup\$
    – Toby
    Aug 5 '16 at 9:28
