I am trying to use Find similar object in Altium designer to change all designator font in my schematic at once. First I Right-click on any designator on the schematic and select Find similar object and Ok. this makes all designators in the sheet to be highlighted. Sch inspector is opened and I select FontId to change the required font. Later I expect that all designator fonts will immediately be changed but actually nothing is happened, Why?!
1 Answer
That is because you must Enable "Select Matching" in Find similar Objects. Then press OK and continue to change FontID. That should work!
