This might be a follow-up/related question to the one previously asked on StackExchange here.
My question is: in an auto-ranging DMM, would I be able to capture transient current profiles - for example using the image below from TI AN092 as reference, if a BLE SOC is going from ~1uA in hibernate mode to ~30mA in transmission mode, within a period of 10s of microseconds, and the 30mA spike lasts for 10s of microseconds itself, is this something the DMM would be able to capture with auto-ranging?
The TI App-Note refers to using a scope to capture the current profile. But would I be able to capture this using a DMM?
What trade-off in terms of accuracy vs capturing transient spikes like the one above, should one be aware of when trying to capture a current profile similar to the one above, using a DMM in auto-range mode?
    \$\begingroup\$ Are you in fact asking what equipment will be suitable to buy. A standard DMM will not do what you want. My advice: do some research on devices that can capture waveforms. \$\endgroup\$ – Andy aka Aug 7 '16 at 9:39
Well first of all, you'll need to give a specification for the DMM. Perhaps a high-quality lab multimeter could be useful, but in my opinion a simple hand-held DMM will almost certainly have too low sample rate to be able to capture what you want to see, even if you didn't have issues with range switching. Some multimeters might have sampling frequency as low as single digit value in hertz. If you take a look at the oscillogram, you can see that the scope is in 500 µs/division mode, so for example the pre-RX feature is around 100 µs long. I'm a bit skeptical of the possibility of capturing something like that with a multimeter.
One trick that's used on auto-ranging multimeters is to first manually check the ranges you have available and then switch to appropriate range by hand before measurement. Almost all auto-ranging multimeters will have option to select range by hand and this way, you won't have any issues with the gap that's created by range switching.
On the other hand, it could be that your multimeter doesn't have high-enough resolution in the high range, so you'll be missing out on the resolution with low current. High-count multimeters can help here, because their ranges will usually cover greater amount of values that can be displayed.
Read the specs on your DMM to determine the sampling rate. It is almost certainly too slow to capture microsecond-scale events.
By the way, most DMMs take a considerable time (sizable fractions of a second) to range.
You need an oscilloscope.
