I'm using HAL API for programming, I programed if UART got some certain text then display the counter in character LCD, Then increment counter, If again got that sentence repeat these (Increment counter and displaying that).(I'm getting by interrupt) When I send about 200 char, two times, everything are right, But (sending) after this ,LCD(Used with I2C expander) missing it's functionality . & if I sending less character in each time I can send characters more than two time .
LCD is based on HD44780
This is schematic: enter image description here And this is cod:(switch is for detecting that certain code,access indicators are LS and LF)
    /* Includes ------------------------------------------------------------------*/
#include "stm32f1xx_hal.h"
/* USER CODE BEGIN Includes */
#include "hd44780.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
I2C_HandleTypeDef hi2c1;
UART_HandleTypeDef huart1;
DMA_HandleTypeDef hdma_usart1_tx;
DMA_HandleTypeDef hdma_usart1_rx;
/* USER CODE BEGIN PV */
            unsigned short flag_acc=0;/**/uint8_t index_tok[12],index_tag[6]/*buffer localization*/, c=0/*index_tag counter*/
            ,rx_index=0/*for locar reception*/,chsumt=0;short err=0/*error occurence*/
            ,errtemp=0/*extreme erorr occurence check*/;
            char /*gl_rx_sz,*/rx_data[1],tx_buf[100],rx_buf[200],chck,test=0,RXNE=-1;
short LS/*Last Sentence*/=0,LF=0/*is in Line Feed char??*/,i2cer=0,ii=0;
typedef enum{
    gsv_off=0,
gsv_on,
    rmc_off,
    gll_off,
    gga_off,
    gsa_off,
    gla_off
}ubx;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_I2C1_Init(void);
/* USER CODE BEGIN PFP */
void gps_baud();
//#ifdef __GNUC__
//  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
//     set to 'Yes') calls __io_putchar() */
//  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
//#else
//  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
//#endif /* __GNUC__ */
//  * @brief  Retargets the C library printf function to the USART.
//  * @param  None
//  * @retval None
//PUTCHAR_PROTOTYPE
//  /* Place your implementation of fputc here */
//  /* e.g. write a character to the USART */
//  HAL_UART_Transmit_DMA(&huart1, (uint8_t *)&ch,1);
//  HAL_Delay(1);
//  return ch;
void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart){// maybe some algorithm needed to declare the error
NVIC_SystemReset();
void HAL_I2C_ErrorCallback(I2C_HandleTypeDef *huart){// maybe some algorithm needed to declare the error
NVIC_SystemReset();
//Interrupt callback routine
 void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
    if (huart->Instance == USART1)  //current UART
            rx_buf[rx_index++]=rx_data[0];                                  //receiving process
            if (rx_data[0]==0x24/*$*/){index_tag[c++]=rx_index-1;LS=1;}//LF indicate end of buffer
            else {
                    if(rx_data[0]!=0x0D/*LF*/){
                        switch (LS)
                            case 1:
                                if (rx_data[0]=='G')LS+=1;
                                break;
                            case 2:
                                if (rx_data[0]=='P')LS++;
                                break;
                            case 3:
                                if (rx_data[0]=='G')LS++;else LS=0;
                                break;
                            case 4:
                                if (rx_data[0]=='S')LS++;else LS=0;
                                break;
                            case 5:
                                if (rx_data[0]=='A')LS=-1;else LS=0;/*last sentense reached*/
                                break;
                            default:
                                break;}
                    else LF=1;
            }//obtain indexes tag
HAL_UART_Receive_DMA(&huart1, rx_data, 1);
                /*write flag. it must implement in main while :)*/
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
void ubx_message(ubx ubx);
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  MX_I2C1_Init();
  /* USER CODE BEGIN 2 */
//  gps_baud();
ubx_message(gsv_off);while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TC)==0);HAL_Delay(5);
ubx_message(rmc_off);while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TC)==0);HAL_Delay(5);
ubx_message(gll_off);
    LCD_PCF8574_HandleTypeDef   lcd;
    lcd.pcf8574.PCF_I2C_ADDRESS = 0x27;
    lcd.pcf8574.PCF_I2C_TIMEOUT = 50;
    lcd.pcf8574.i2c.Instance = I2C1;
    lcd.pcf8574.i2c.Init.ClockSpeed = 40000;
    lcd.NUMBER_OF_LINES = NUMBER_OF_LINES_2;
    lcd.type = TYPE0;
LCD_Init(&lcd);
LCD_SetLocation(&lcd,0,0);
LCD_WriteString(&lcd,"/*/*/*/*/*/*/*/*");
HAL_UART_Receive_DMA(&huart1, rx_data, 1); //activate uart every time receive 1 bit
__HAL_UART_ENABLE_IT(&huart1,UART_IT_ERR);//error interupt enabled
__HAL_UART_ENABLE_IT(&huart1,UART_IT_PE);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
        //error handler ***
        if(0x01==__HAL_UART_GET_FLAG(&huart1,UART_FLAG_ORE)||0x01==__HAL_UART_GET_FLAG(&huart1,UART_FLAG_PE)||err!=errtemp){
        NVIC_SystemReset();
        }//error handler end ***
    if(LS==-1&&LF==1)
//      HAL_UART_Transmit_DMA(&huart1, tx_buf,100);
            LCD_WriteString(&lcd,"we detecting sth.");
            LCD_SetLocation(&lcd,0,1);
            LCD_WriteFloat(&lcd,ii++,2);
LS=0;
LF=0;/*refresh Line Feed for next recieve*/
            rx_index=0;
    HAL_UART_Transmit_DMA(&huart1, "|",1);
    HAL_Delay(50);
    HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_3);
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* I2C1 init function */
  hi2c1.Instance = I2C1;
  hi2c1.Init.ClockSpeed = 100000;
  hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
  hi2c1.Init.OwnAddress1 = 0;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c1) != HAL_OK)
    Error_Handler();
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 9600;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  * Enable DMA controller clock
  /* DMA controller clock enable */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Channel4_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel4_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel4_IRQn);
  /* DMA1_Channel5_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel5_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel5_IRQn);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_2|GPIO_PIN_3, GPIO_PIN_RESET);
  /*Configure GPIO pins : PA2 PA3 */
  GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void ubx_message(ubx ublx)
    switch (ublx)
    case gsv_off:
            HAL_UART_Transmit_DMA(&huart1, "\xB5\x62\x06\x01\x03\x00\xF0\x03\x00\xFD\x15",11);
    break;
        case rmc_off:
            HAL_UART_Transmit_DMA(&huart1, "\xB5\x62\x06\x01\x03\x00\xF0\x04\x00\xFE\x17",11);
        break;
        case gll_off:
            HAL_UART_Transmit_DMA(&huart1, "\xB5\x62\x06\x01\x03\x00\xF0\x01\x00\xFB\x11",11);
        break;
        case gsv_on:
            {uint8_t mess[11]={0xB5,0x62,0x06,0x01,0x03,0x00,0xF0,0x03,0x01,0xFE,0x16};
            HAL_UART_Transmit_DMA(&huart1, mess,11);}
        break;
    default:
        break;
void gps_baud()
    HAL_UART_Transmit_DMA(&huart1, "$PUBX,41,1,0007,0003,115200,0*18\n\r",35);
      huart1.Init.BaudRate =115200;
  HAL_UART_Init(&huart1) ;
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
  • \$\begingroup\$ Please add schematic and code. \$\endgroup\$ – Bence Kaulics Aug 8 '16 at 12:35
    \$\begingroup\$ That's not a schematic. \$\endgroup\$ – brhans Aug 8 '16 at 12:51
  • \$\begingroup\$ Then what's schematic? o_O Schematic of what u need? Please help. \$\endgroup\$ – mohammadsdtmnd Aug 8 '16 at 12:53
  • \$\begingroup\$ We don't know what is attached to your microprocessor, and how. Please provide \$\endgroup\$ – Voltage Spike Aug 9 '16 at 18:11
  • \$\begingroup\$ Ok, But the question is answered, I will do that for my next question, ty. \$\endgroup\$ – mohammadsdtmnd Aug 10 '16 at 13:27
Not sure if it's the cause or not but you have some horrible buffer overflow bugs in there which will crash your code.
You have the command index_tag[c++] in your ISR. I can't see anywhere where c is reset to 0 which means after hitting that line 12 times you'll be overflowing the memory allocated to index_tag. (I may have missed this, c is not the easiest variable name to search for.) Similarly your rx buffer index can easily overflow. You reset it if the correct condition is hit but if that condition isn't met you'll overflow the rx buffer and crash.
  • \$\begingroup\$ OMG, How u found it. I will test and report answer. Ty so much \$\endgroup\$ – mohammadsdtmnd Aug 8 '16 at 14:15
  • \$\begingroup\$ Yes it worked, God bless u \$\endgroup\$ – mohammadsdtmnd Aug 8 '16 at 14:32
  • \$\begingroup\$ Working for a while and then crashing is almost always software not hardware. If it's in c / c++ then the issue is almost always writing past the end of an array, an uninitialized pointer or a memory leak. You aren't using pointers or dynamic memory which only leaves one type of bug to look for. \$\endgroup\$ – Andrew Aug 9 '16 at 8:05
  • \$\begingroup\$ What I must search in net. , To learn programming with dynamic memory \$\endgroup\$ – mohammadsdtmnd Aug 10 '16 at 13:25
