Consider an inductive charging system like Magne Charge - it has a rather huge "coupler" coil off the vehicle and a corresponding slot on the vehicle and the coils in the "coupler" and in the slot are aligned perfectly parallel and brought close to each other. So it looks like a good old transformer.
Yet there's a huge box in each Magne Charge system (a wall-mounted unit) that most likely generates higher frequency current. Btw this box seems to be accountable for huge energy losses.
What's the need for that frequency increase? A good old transformer will run at the same frequency as mains - 50 or 60 Hz depending on the region - and have pretty good efficiency. Why would this slightly altered transformer setup need higher frequency?
    \$\begingroup\$ Good old transformers weight hundreds of grams (more than your cellphone) and require both winding to be on a common ferromagnetic core to be efficient. \$\endgroup\$ Commented Oct 29, 2015 at 11:35
6
It all boils down to efficency.
As the frequency a transformer runs at increases, the transformer can be physically smaller.
To Plagiarize Quote Wikipedia:
The EMF of a transformer at a given flux density increases with frequency. By operating at higher frequencies, transformers can be physically more compact because a given core is able to transfer more power without reaching saturation and fewer turns are needed to achieve the same impedance.
Consider the size required for a 50/60 Hz transformer capable of 6.6 - 50 KW (the power rating range of the Magne-Charge systems).
  • \$\begingroup\$ So basically the efficiency aspect optimized for here is the coupler/slot size, isn't it? \$\endgroup\$
    – sharptooth
    Commented Jan 16, 2012 at 10:07
  • \$\begingroup\$ Well, you have two different concerns - Coupler size/weight, and efficiency, with an inverse relationship. You have to pick somewhere along the rance of possibilities. I can't put my self in the system designer's shoes, but I would imagine accessibility was pretty high on the importance scale. After all, granny has to be able to lift the charge paddle to charge her shiny new electric car, doesn't she? \$\endgroup\$ Commented Jan 16, 2012 at 10:17
  • \$\begingroup\$ I see. Could the same work with a mains-frequency transformer if the "coupler" was wall-mounted and the vehicle had a side-mounted counterpart for the coupler and was parked perfectly close to the wall-mount coupler? \$\endgroup\$
    – sharptooth
    Commented Jan 16, 2012 at 12:05
    \$\begingroup\$ @sharptooth - Kind of. The tolerances are tiny. You need essentially no air-gap, or you lose efficiency in a hurry. I don't have hard numbers (It's kind of a nebulous design, too), but a gap of even 1 mm would ruin things. Really, you should think of it as needing physical contact. It's basically a circuit, just like any other, just magnetic, rather then electrical. \$\endgroup\$ Commented Jan 16, 2012 at 12:28
The frequency also affects safety too. The higher the frequency, the less likely the system will interact with biological objects when in operation. This is very important.
    \$\begingroup\$ Microwaves have very high frequency, they are also known to interact with biological objects rather intensively. \$\endgroup\$ Commented Oct 29, 2015 at 11:39
-1
The high frequencies create a high voltage i.e. e=4.44n(phie)(f); so by increasing f we may increase the EMF which is helpful in induction in the second coil.
  • \$\begingroup\$ Your answer is not completely clear, could you clarify? \$\endgroup\$
    – Kortuk
    Commented Jul 5, 2013 at 13:38
