6
This is a schematic for a very simple guitar pre-amp. I understand the basic amplifier architecture except for those two 33k resistors in the middle, combined with the 220nF capacitor. Any ideas as to what those are for?
  • 5
    \$\begingroup\$ I'm not real knowledgeable about tube amps, so I'll make this a comment. That appears to be negative feedback to control the gain and linearity. See figure 5.6 for a circuit very much like yours. \$\endgroup\$ – JRE Aug 11 '16 at 15:46
    \$\begingroup\$ Figure 5.11.1 is another example of negative feedback. \$\endgroup\$ – JRE Aug 11 '16 at 15:49
  • \$\begingroup\$ @crocboy: Do you already follow why the grid leak resistors exist? \$\endgroup\$ – jonk Aug 11 '16 at 18:20
  • \$\begingroup\$ Does this resemble an op amp feedback network to anyone else...? \$\endgroup\$ – ThreePhaseEel Aug 11 '16 at 22:14
17
It's (capacitively coupled)negative feedback so the gain is controlled about 66K/1K = 66.
The feedback is applied to the cathode of V1a rather than the grid because it needs to be negative feedback.
