I am using 7805 and 7815 for the voltage 5 V and 15 V respectively. I provide 24 V to 7815 it is giveinng me output voltage 18.5 V instead of 15 V. According to 18.5 V to input to 7805, its output is 6 V. It should have to provide 5 V output. similarly, the output of 7815 should be 15 V.
I don't know what is happening. Can you tell me what will be the error in the circuit?
I am using this schematic in hardware.
  • 5
    \$\begingroup\$ With no load the regulators will find it hard to regulate. Connect it to a simple resistive load (say a 1KΩ resistor) and measure the voltage then. \$\endgroup\$
    – Majenko
    Commented Aug 12, 2016 at 18:53
  • \$\begingroup\$ That doesn't really qualify as a full schematic. "Can you tell me what will be the error in the circuit?" Not with the little information you gave. \$\endgroup\$
    – Transistor
    Commented Aug 12, 2016 at 18:58
    \$\begingroup\$ @Jim Until the pot catches fire as you hit the last few mm of track... ;) \$\endgroup\$
    – Majenko
    \$\begingroup\$ I've seen a 7905 give too high an output without a load, but never a 7805. Not sure what that means. \$\endgroup\$ Commented Aug 12, 2016 at 19:18
  • 5
    \$\begingroup\$ Is it possible that your meter is off? A 1 volt error at 5 volts and a 3.5 volt error at 15 volts suggest this possibility. \$\endgroup\$
    – Barry
    Commented Aug 12, 2016 at 19:20
9
You need a minimum load for them to regulate. Add a resistor to give 100 uA of load and the situation should improve.
Your circuit is fine. The battery in your meter needs to be replaced.
The voltmeter is reading high by more than 20% because the internal voltage reference has gone out of regulation (low) and the readings are a ratio like Reading = K * Vin/Vref.
  • 10
    \$\begingroup\$ If OP accepts this you will earn +1 for mindreading. \$\endgroup\$
    – The Photon
    Commented Aug 12, 2016 at 20:06
6
I know this is dead but I had the exact same issue. Turns out I had the chip backwards. L7805cv
