We need a pseudo-random clock with a length N, in such a way that out of every N clock pulses, M of them should randomly made zero (M<<N). What we want to do is to sample a signal in a random fashion. Meaning that, out of every N sample points (from Nyquist grid) we need to take M samples. Then through some processing and assumptions about signal structure, other un-sampled (N-M samples) points are recovered. Now I am using Linear Shift Registers, something like below:
It works good, however, I do not want equal distribution for 1s and 0s, I mean I want something like 20% of clock cycles to be 1 and 80% to be zero. To achieve that, I made to AND output of two circuits like above to change probability from 50% for both 1s and zeros to 25% for 1s and 75% for zeros (in figure below, with different seeds).
It is good at the cost of doubling the power and chip area:( . I am seeking a way to make the system work with only 1 random clock generator circuit, not two.
  • Is possible through implanting some special initial seed change probability distribution of 1s and 0s in output sequence ?
  • Is there any power-area efficient method to accomplish this?
I was thinking to store a random binary sequence (with length of N) in a ROM and then And its output with the clock to make a random clock.
    \$\begingroup\$ Depends how random it needs to be. If storing a sequence in a ROM is not an issue, then you could also use an LFSR to make a pseudo-random sequence. A bit more info on the application would help. \$\endgroup\$ Commented Aug 14, 2016 at 17:46
  • \$\begingroup\$ I second the lfsr. look for "irreducible polynomial" and pick which one gives the variations you want \$\endgroup\$
    – b degnan
    Commented Aug 14, 2016 at 17:56
  • \$\begingroup\$ The clock frequency is up to 1Mhz \$\endgroup\$
    – MimSaad
    Commented Aug 14, 2016 at 18:03
  • \$\begingroup\$ explain "M of them should randomly made zero " random edge, what min max time range and coherent with 1MHz? Random phase? \$\endgroup\$
    – D.A.S.
    Commented Aug 14, 2016 at 18:44
    \$\begingroup\$ Wouldn't it be easier to simply take all of the samples at the full clock rate and then randomly discard some of them? \$\endgroup\$
    – Dave Tweed
    Commented Aug 14, 2016 at 23:11
Think of the contents of the N-bit LFSR as an N-bit integer. This number will have a uniform distribution of values from 1 to 2N - 1. You can generate a variable density of mask bits by comparing this number to a threshold that you also vary from 1 to 2N - 1. The output of this comparator is the clock mask you seek.
  • \$\begingroup\$ This method is flexible in changing distribution, so when I want like 17% of 1s, I'll set the threshold to 0.17*(2^N-1). I'll check to figure out if it is area and power efficient too. \$\endgroup\$
    – MimSaad
    Commented Aug 15, 2016 at 17:35
  • \$\begingroup\$ The answer is great and provides flexible distribution, however it stills requires an Comparator. I am researching to find out if I only use a few bits of N bit random generator and compare it to a threshold can acviehve good performance. \$\endgroup\$
    – MimSaad
    Commented Aug 17, 2016 at 14:24
    \$\begingroup\$ Yes, of course. Any subset of M bits from the N-bit LFSR will contain a uniform distribution of values from 0 to 2^M - 1. So if you only need one part in 2^M resolution in your threshold settings, you can just use an M-bit comparator. \$\endgroup\$
    – Dave Tweed
    Commented Aug 17, 2016 at 20:51
