7
This weekend a very close lightning strike took out several devices in my house. Among the casualties were:
  • 2 TVs
  • 1 cable modem
  • 1 cable box
  • 1 garage door opener
One of the TVs, the cable modem, and the cable box were all plugged into power supplies that reduced 120 VAC line voltage to 12 VDC (or similar). I tested all the transformers and they are all fried (none of them produce anywhere near their rated output now).
I replaced the cable modem and cable box, but the TV is an expensive item I'd like to salvage if possible. I can replace the power supply for about $15. Is there any chance that the supply "took the hit" and provided enough protection to save the TV? I don't have an easy way of testing it without just buying the replacement supply.
As a more general question, how much protection do consumer grade power supplies provide against voltage fluctuations? I know there's nothing consumer grade that will stop a direct lightning strike, but do they provide effective protection against voltage spikes and drops caused by other disturbances?
EDIT: As it turns out, the $15 power supply did "take the hit" and protect the TV.
    \$\begingroup\$ I've edited your post to make it clear that you're talking about external "wall wart" power supplies, not the specific magnetic component that EEs call a "transformer". This should get you better answers. \$\endgroup\$
    – Dave Tweed
    Aug 15, 2016 at 23:00
6
There are two kinds of surges, differential-mode and common-mode.
A differential-mode surge means that the voltage difference between line and neutral rises to an abnormal value. This type of surge can be caused by a lightning strike on a distant high-voltage feeder line, which then gets transformed by your local distribution transformer to a correspondingly high voltage at your service entrance.
A common-mode surge means that all of the wires experience the same abnormal voltage at the same time. This type of surge can be caused by a nearby lightning strike, which can cause the "ground" in the vicinity of your house to have a much higher voltage than "ground" much farther away. It can also cause large currents to flow in any wiring "loops" in your house, which also induces common-mode voltage shifts.
So, taking your more general question first, a typical wall-wart power supply will generally protect and/or "take the hit" for any differential surges. There are relatively few mechanisms by which a primary-side overvoltage would be coupled to the DC output. Most power supplies have spark gaps and/or MOVs to make sure that the primary voltage doesn't exceed the isolation rating between primary and secondary. (In fact, I'm fairly certain that such protection — at least up to a certain energy level — is a requirement in order to get a safety rating such as UL.)
However, these mechanisms cannot do anything for common-mode surges. A common-mode surge could easily exceed the isolation rating of the supply and cause the DC connection to the device to also experience a common-mode surge. If the device is otherwise isolated, it might survive this, but TVs (and cable boxes, etc.) tend to have another connection — the signal cable that comes from the antenna or cable company.
Now, the cable shield is supposed to be bonded to the same ground as your AC power at your service entrance, and if this is the case, then this should experience the same common-mode surge as everything else and preventing large currents or voltages from appearing. But if it is not, then large currents can flow through the power supply, the TV and the cable shield. The TV is not likely to survive this.
Also, as I alluded earlier, the path from your power service entrance, through your house wiring to the outlet, through the power supply, the TV and the cable connection forms a large "loop" with a significant amount of area. A lightning strike that's close enough can induce a large common-mode current in this loop even if the cable is properly grounded at the service entrance.
So, in spite of all of that, the bottom line is that no one can say for sure one way or the other whether or not your TV survived. For $15, it's certainly worth a try. If you're an electronics hobbyist (I presume you already have a multimeter of some sort), then investing in an adjustable bench power supply would be worth your while, because in addition to all of its other uses, you could use it to test the TV before committing the money for a new dedicated supply. Units that can produce 0 - 30 V at up to 3 A are readily available at very reasonable prices.
Anything between the source of the voltage spike and connected appliances will provide some protection. Everything that carries current to the ultimate load has some impedance and offers an alternate fault path for current. The amount of protection that provides in not insignificant, but it is an incidental benefit, not what the devices and wiring materials are designed to do.
Transformers and power supplies probably provide a great deal of protection from voltage spikes. A power supply that has failed may have completely protected the connected device from a line-to-line voltage spike, but still allowed damage resulting from line to ground (common mode) voltage.
There is no way to know if something has been protected by its power supply other than replacing the supply and attempting to operate the device. If you examine the product carefully and see something that looks burned, there is a good chance there is damage. But the lack of such evidence doesn't guarantee there is no damage. You might even find that the device appears to work, but fails a week or a month later.
