weird Component
I was wondering what is the name of this component, it really doesn't really have a part number, or anything similar so my research has really gone down to a low. Researching silver disk thingy does not help either.
I found this part in a microwave, as well as in an old CRT TV, along with a bunch of other good parts. What is the name, and purpose of this component?
  • \$\begingroup\$ It's a piezo disc, used to make basic beeping sounds, like the beep from the microwave when its finished. I'm not sure what its doing in your TV. \$\endgroup\$
    – Steve G
    Aug 20, 2016 at 16:58
  • \$\begingroup\$ @SteveG SAME ON THE TV PART!!!!!!!!!!! \$\endgroup\$ Aug 20, 2016 at 16:59
  • \$\begingroup\$ @SteveG Its an old TV so I don't know. \$\endgroup\$ Aug 20, 2016 at 16:59
You can learn more about it here. It involves the piezoelectric effect which is more physics, but basically when a stress is applied to piezoelectric material a current is created.
  • \$\begingroup\$ One can use this as a noise maker or noise sensor near its resonant frequency. example communica.co.za/catalog/Details/P1362893234 \$\endgroup\$ Aug 20, 2016 at 17:06
  • \$\begingroup\$ @darkness - Alternatively, it can also be used to convert stress into a voltage. \$\endgroup\$ Aug 20, 2016 at 17:32
  • \$\begingroup\$ @Whiskeyjack Yes I was going to put that but thought current was better for the OP's level. \$\endgroup\$ Aug 20, 2016 at 17:34
