I have a 3D printer. Its control board gets too hot - it works but it get too hot.
I want that the current of the hotend flows through a MOSFET source ->mosfet (using ramps output as signal)->hotend to the hotend and not form the source ->ramps->hotend.
I discovered that if I touch the ground of the source and the ground of the hotend control board output it automatically turns on without command, so I had to use some isolator.
I built the following circuit; I use a 4N35 for isolating the hotend controlboard output, and then use a PNP transistor to connect the gate from the MOSFET to the 12 V rail. I put 2 diodes to step down the voltage to 10 V. I want to use an IRF740N.
I don't know if my circuit is wrong or if it's my circuit simulator that is wrong because the MOSFET is always on.
In theory the pnp transistor should be open if no voltage is aplied in the base, so the mosfet will be off, but in my circuit simulator its always on, and i dont know why, i dont know if my circuit is bad or my simulator has a bug.
I build this circuit enter image description here i replace the diodes becouse the hotend is controlled by pid, so needed a faster diodes.
So i choose to divide the current with resistor
after building the circuit i realize that the circuit simulator was wrong, i am using livewire 1.14. The circuit actualy work as intended.
But after conected it in to the ramps dosent work, but stand alone with a led and a power supply works fine.
I research a litte and discover that the heat come from the 5v regultor from the arduino board.
The reason of the heat wasen't the mosfet or the hotend, it was the graphics lcd that draws too mach current of the arduino regulator.
The solution is to remove one diode of the ramps and feed external 5v in a pin, so the regulator it's dosent need it. but i dont know why when i pluged the second circuit it dosent work, for somebody who knows the ramps 1.4 board maybe can solve the problem
I consider my problem solved,and learned a lot about mosfet in the experince, thanks a lot to those that really wants to help people and are very humble
    \$\begingroup\$ i forget to put the resistor in the way to 4n35 but i wanna know if this circuit is ok \$\endgroup\$ Aug 22, 2016 at 23:45
    \$\begingroup\$ When should the MOSFET turn off? You don't have a path to ground, the gate is simply high or floats. \$\endgroup\$
    – pipe
    Aug 22, 2016 at 23:53
  • \$\begingroup\$ disrespect? do i insulted somebody? not everybody person in this planet speak english in native form, and for today more people speak chinise, so dont be so agressive if you see some typing errors, if you dont like some question go foward, complaing and insulting about others typing its not helpfull,speaking from the circuit i forgot putting the resistor from the gate to ground, but anyway it still operating the sameway, its reverse, when i close the button current from the r1 resistor stop flowing and when is open flows, i want the oposite effect \$\endgroup\$ Aug 23, 2016 at 5:15
  • \$\begingroup\$ You need a resistor from Q1 gate to its source - this is what @pipe is hinting at. Probably either 10k or 1k will work. \$\endgroup\$ Aug 23, 2016 at 10:28
  • \$\begingroup\$ @jorgeneo560 You look smarter if you punctuate and use capitalization in your sentences. You might have grammar issues because of translation, but it is unprofessional to not capitalize. At least correct the spelling. It would also help your reading to ask an actual question in the post and format the paragraphs for easy reading. \$\endgroup\$
    – Voltage Spike
    Aug 23, 2016 at 16:25
(1) Q1 MUST have a "pulldown" resistor from Q1_gate to Q1_source to turn it off when Q5 is not on. At present when Q5 is off, A5 collector floats, so Q1 gate floats, so the MOSFET Q1 could be off or on or in betwee.
(2) Q5 base needs a resistor to 4N35 output to limit LED current. You know that.
(3) To change "sense" of operation so that Q1 is on when the button is pressed.
  • Change Q5 to an NPN with collector to Q5 gate and emitter to ground,
  • Change optocoupler to between Q1 base and V+12 via a resistor.
I forget to put the resistor in the way to 4n35 but i wanna know if this circuit is ok –
As this MAY be the most important issue you MUST show your actual circuit. It is not obvious that you mean what you say there.
As you also say
But the 4N35 connects to Q5 base, and Q5 does not have a gate. You MUST show your complete and correct circuit.
And you say both
becouse the mosfet is always on
and
These are quite different things AND all the information should be edited into your question.
____________________
Presentation matters:
To get good answers you MUST take notice of the following.
Questions which do not adhere to basic good presentation rules are more often than not also poor questions technically (a perhaps little known fact).
Your question MAY be OK technically, or not, but its poor presentation makes it hard to read, and people will down-vote it and close it.
Arguing about this will not help you - learn to follow the basic rules.
Do NOT use all small letters - capitalise the start of sentences.
Use I for I and not i.
Break sentences up with punctuation and add spaces between paragraphs where needed.
Ignore Olin's rudeness and do not be rude in return. If you fight with Olin and similar you will lose - the moderators will put your question on hold.
Your errors are largely not 'typing errors' but are made by choice.
Instead of
i had a 3d printer, the control board gets too hot, it work but it get too hot, and i want that the current flows trought the source to the mosfet and then to the hotend, i discover that if i touch the ground of the source and the ground of the hotend control board output its automaticly turns on wihtout command, so i had to use some isolator, i build this circuit, i use a 4n35 for isolating the hotend controlboard output, and then use a pnp transistor for conecting the gate from the mosfet to the 12v, i put 2 diodes to step dow the voltage to 10v, i wanna use the irf740n , i dont know if my circuit is grong or its my circuit simulator that its bougus becouse the mosfet is always on
Do something like:
I have a 3D printer in which the control board gets too hot.
It works but it gets too hot, and I want that the current flows through the source to the MOSFET and then to the hotend.
I discovered that if I touch the ground of the source and the ground of the hot-end control board output it automaticly turns on without command, so I had to use an isolator.
I build this circuit, using a 4N35 for isolating the hotend controlboard output,...
  • \$\begingroup\$ thanks, now we are talking, you had been very usefull, i correct my answer and the circuit \$\endgroup\$ Aug 23, 2016 at 20:52
