I want to send a board off for fab + assembly soon which will include various jumpers in 2 or 3 pin configurations. For example, see this picture below (sorry about quality). I'd like to specify the 2P header to have a jumper installed, and for the 3P header, the jumper is installed on pins 1-2.
jumper configuration example
Is there any standard way of specifying this in either the BOM, Gerbers, or elsewhere? At prototype levels I can install them myself but at production this is infeasible. I'm sure worst case I can include a readme file with assembly notes.
  • \$\begingroup\$ Do you have any mechanical drawings to accompany the gerbers and BOM? Generally you should include mechanical drawings, on which you can add notes saying "place jumper between position 1 & 2" or the like. Then just be in close contact with your manufacturer and make sure they know the note is there and what it means \$\endgroup\$
    – DerStrom8
    Aug 23, 2016 at 15:18
  • \$\begingroup\$ Worst case, yes, you could add a readme file, but it's much better for the manufacturer to be able to see what you're referring to \$\endgroup\$
    – DerStrom8
    Aug 23, 2016 at 15:20
Gerbers are not the right place to put such information, as they are meant for PCB manufacture only.
I would create an Assembly Drawing document that shows how components are placed and add any necessary notes for jumpers.
Here's a snippet from one of my assembly drawings.
  • \$\begingroup\$ Hmm, this sounds familiar.... =P \$\endgroup\$
    – DerStrom8
    Aug 23, 2016 at 15:52
  • \$\begingroup\$ @DerStrom8 I would probably have moved on, if you had posted your comment as an answer :) \$\endgroup\$
    – Armandas
    Aug 23, 2016 at 15:57
  • \$\begingroup\$ Fair enough, you got me there ;) \$\endgroup\$
    – DerStrom8
    Aug 23, 2016 at 16:17
  • \$\begingroup\$ Thanks a lot. Seems like assembly drawing is the cleanest way to do it. Marked as the answer. \$\endgroup\$
    – Jim
    Aug 23, 2016 at 16:44
