I want to implement the following signal:
I(t) = 500*(sin(pi.t/0.3))^2, t belongs {0,Ts}
= 0, t belongs {Ts,T}
Here, T = 0.8 and Ts = 0.3
The code I tried:
t = 0 : 0.001 : 25;
d = 0 : 0.8 : 25;
y = pulstran(t,d,'rectpuls',0.3);
ut = 500.*((sin(pi*t/0.3)).^2).*y;
plot(t,ut)
xlabel 'Time (s)', ylabel Waveform
The generated waveform deforms greatly, for example the generated waveform does not consist of uniformly spaced peaks.
Edit: Modified the code but still issues remain.
    t = 0.01 * [0:3000]';
    d = 0.8 * [0:1500]';
    ut = 500.*((sin(pi*(t-floor(t/0.8)*0.8)/0.3)).^2).*y;
    plot(t,ut)
Mainly, instead of 1 peak for the 0.3s ON state, there are two peaks.
  • \$\begingroup\$ Its not possible with the information you supplied, \$ sin^2(\theta) \$ has a period of 0.3 (for T) and your T is 0.8 edit the question. If you want to transfer the period use \$ sin^2(\theta) = (1 - cos[2\theta])/2\$ \$\endgroup\$ – Voltage Spike Aug 23 '16 at 18:47
  • \$\begingroup\$ The function results such that for 0-0.3s, the sin^2 wave is generated. For 0.3-0.8s, the value is 0. Then again, for next 0.3s, the sin^2 wave is generated as it t = 0 to 0.3. Then 0 for for next 0.5s. And so on. \$\endgroup\$ – Rachit Ajitsaria Aug 25 '16 at 12:15
  • \$\begingroup\$ Its unclear to me what kind of period you want to cutoff the \$ sin^2\$ wave. The \$ sin^2\$ wave has a period of 0.3 on the scale of 0 to 0.3 where do you want the \$ sin^2\$ wave to be cutoff to zero? \$\endgroup\$ – Voltage Spike Aug 25 '16 at 15:59
  • \$\begingroup\$ After one time period (0.3s), the input should go to 0 for the next 0.5s. After that it should resume for one time period (0.3s). And reduce to 0 again. And so on. @laptop2d \$\endgroup\$ – Rachit Ajitsaria Aug 28 '16 at 9:44
  • \$\begingroup\$ If you zero out the \$ sin^2\$ wave out for 0.5 seconds , it will cut out more than one of the \$ sin^2\$ periods \$\endgroup\$ – Voltage Spike Aug 29 '16 at 15:25
I still don't understand what your period is, so I generated two ways to do this. The first method creates a mod vector of the time and generates a zero vector, the zero vector zeros out the data. As shown in the first figure.
t = 0 : 0.001 : 2;
T = 0.8;
Tz = 0.4; %this is T = Tz + Ts
yy = mod(t,T) %create mod vector to periodize time vector
yy(yy>Tz) = 0; %zero out unwanted portion of vector
ut = 500.*((sin(pi*t/T)).^2);
utt = ut.*(yy>0); %this is the zeroed out sine wave
figure,plot(t,ut),hold on,plot(t,(yy>0)*500,'g');
plot(t,utt,'r+')
legend('i(t)','Mod time vector','sin^2(t) zeroed out')
td = 0.001; %time vector resoult
T = 0.8;
Tgap = 0.34; %vector gap
Tend = 2;
t = 0:td:Tend;
ttt = [0:td:T-td zeros(1,round(Tgap/td))]; %create vector with zero gap
tt = repmat(ttt,1,1+round(length(t)/length(ttt))); % repeat the vector for as long as the time vector is +1
tt = tt(1:length(t)); %truncate it to be the same size as the time vector
ut = 500.*((sin(pi*tt/T)).^2);
figure;plot(t,ut),xlabel 'Time (s)', ylabel Waveform
This one creates a gap in between each \$ sin^2(t)\$ function, it does this by creating an time vector with zeros in it and then replicating the vector. I didn't use the same time periods so you would have to go through the code and figure it out for yourself.
