I have a small children's record-player. I'd like to modify it so that it can also play music from an SD card from my phone from the same speaker. After opening the device I see that the output from the needle which has two wires positive and ground goes into what I assume is an amplifier board. I have a SD card mp3 player board which has audio out that can be attached to speakers running at 5V. Should I hook this to the speaker in the player? or should I run it through the built-in board first?
Is the signal from the needle basically the same as the signal going to the speakers just softer?
    \$\begingroup\$ It's softer and it's biased - albums are mastered with lots of HF gain / LF attenuation which needs to be countered in the record player (look up RIAA equalization for more details) \$\endgroup\$ Commented Aug 25, 2016 at 16:46
The needle or pickup is very sensitive and gives out a very low signal - maybe 10 mV or so. Connecting the relatively high level headphone or "line-level" signal from your phone - typically 1 V or so - would cause great distortion. Turning down the phone doesn't really help as the background noise from the phone audio output would not get turned down (as much of this would be generated after the phone's volume control circuit).
Your best bet is to see if you can find the volume control on the record player and hook in there.
Figure 1. The modification.
  • Assuming it's a mono player it will only have one volume control. Your phone will be stereo so you need to feed both channels into the mono volume control.
  • The pickup will be pre-amplified and fed to the volume control before being fed to the "power" amplifier to drive the loudspeaker.
  • You need to find the clockwise end of the potentiometer and connect your audio in as shown in Figure 1. The 10k resistors "mix" the audio and limit the current into the pre-amplifier for safety.
