I bought two of these trimmers from Digikey to tune a resonant circuit, but the screw is covered with silicone. I dug out the silicone with an xacto so I could turn the screw. Why is the silicone there? Seems counter-productive.
  • 4
    \$\begingroup\$ Do you think you could get an in-focus photo and crop it? 98% of your photo is useless background. \$\endgroup\$
    – Transistor
    Aug 25, 2016 at 19:25
    \$\begingroup\$ I suspect it's sealant to prevent contamination during solder reflow and flux washing operations. \$\endgroup\$ Aug 25, 2016 at 19:31
  • 5
    \$\begingroup\$ @BSEE - Don't you mean "silicone", not "silicon"? Silicon is what circuit components are made of. \$\endgroup\$
    – Bort
    Aug 25, 2016 at 19:34
Many trim caps cannot be cleaned. Murata, for example, recommends against cleaning for many of their products:
but they do have some (eg. TZB4 Series) with a 'cover film'.
Recommended procedure after mounting and cleaning:
In Digikey's photo you can see what looks like silicone (rather than the typical polyimide cover film one would expect from the name).
Silicone is good for heat and water resistance such as Thermal Reflow Oven and Aqua solder flux cleaning making it suitable for a variety of assembly processes. It also stabilizes the position from vibration.
I suspect it should be left in.
I haven't tried but isn't this just an outside layer sealant that can be operated with the trimmer tool? Does it affect pF readings?
