I have a part in Eagle that has two pads for VDD (pad 1 and 2) and two pads for VBAT (pads 9 and 10). The pads must be tied together on the PCB so I have designated a single pin for each pair of pads.
With the pins set to show both the pad and pin names, I expect to see VDD as a pin name and 1*2 for its pad name as well as VBAT as a pin name and 9*10 for its pad name. This works fine for VDD but not for VBAT. For some reason, VBAT is showing 9*2 as if it were connected to pad 9 and 2; however, that is not the case.
I am relatively new to Eagle so I'm sure its a simple mistake but I can't seem to figure it out. I have attached screenshot snippets of the relevant information.
