We need to put display under 2mm glass. Our device must have capacitive touch input. which method should we use? Capacitive Touch Films (place it under glass) or LCDs with integrated capacitive touch (place it exactly under glass)? For Capacitive touch film i mean something like this: http://www.buydisplay.com/default/3-2-inch-capacitive-touch-panel-wiith-controller-ft6236-for-240x320-dots
closed as too broad by Peter Smith, Dmitry Grigoryev, Daniel Grillo, JYelton, PeterJ Sep 1 '16 at 12:36
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
Depending on the specific LCD you use, you may find that it will have a layer of glass on the front of the assembly. Adding a further 2mm of glass may push the touch screen over the maximum sensing distance. LCDs with integrated touch panels may or may not be designed to work like this, so it would depend on the model you choose. I have seen datasheets that specify a range of lens thickness that they will work with.
If you use a touch film, you may have more luck. Although I can't see any spec. for touch distance on the one linked. Ideally, you would find that out before committing.
