I was thinking about making my own minimalist TTL CPU for fun and knowledge, when this question came to mind. Basically, if a 1-Bit Computer can only recognize 2 numbers, 0 and 1, doesn't that mean that the computer could only have 2 registers or instructions? Then, I found the Motorola MC14500B, which is a 1-bit computer that has 16 instructions, with 4 pins for opcodes. Is the MC14500B considered a "true" 1-bit computer, since it has more than 2 instructions, and if so, could I apply the same concept to internel registers where there are more than just 2, but the actual logic going on in the CPU and the memory works on 1-bit? This is a simple question that I need some clarification on, so thank you for your help!
  • 5
    \$\begingroup\$ The width of the instruction word and the width of the computational data path do not necessarily need to match, and in many practical designs do not. \$\endgroup\$ Aug 29, 2016 at 4:33
  • \$\begingroup\$ Thiis is somewhat reminiscent of bit slice processor architectures: en.wikipedia.org/wiki/Bit_slicing \$\endgroup\$ Aug 29, 2016 at 12:15
  • \$\begingroup\$ Not answering your question but I would recommend using more bits. Using a 1 bit data path means a lot of control logic to serialize and deserialize all information. If you use 7400 series ICs instead of discrete transitors then there are many ICs with 4 or 8 bit data width and you might actually get something that works before you are old. \$\endgroup\$ Aug 30, 2016 at 6:23
  • \$\begingroup\$ How big is the address space, just out of interest? \$\endgroup\$
    – Ian Bland
    Oct 28, 2016 at 10:47
  • \$\begingroup\$ It's confusing to categorize computers into "bits" since there are so many bits in a computer: instruction word width, data word width, memory address space width, which one do you want it be one bit? \$\endgroup\$ Oct 28, 2016 at 13:33
Yes, you can have many more than 2 internal registers and still have a 1-bit datapath and data register width. So yes, the Motorola MC14500B is considered a true 1-bit microprocessor. Like most processors, its instructions are wider than its data. From your description, it sounds like you would need instructions wider than MC14500B instructions so those instructions would have room for the operand specifiers; each operand specifier wide enough to pick one register.
The Wikipedia "1-bit architecture" says
A 1-bit computer architecture is an instruction set architecture for a processor that has datapath widths and data register widths of 1 bit wide.
You might also consider a serial computer architecture, like every computer built before 1951, which relaxes one requirement and allowing data register widths much wider than 1 bit, but keeps the datapath widths 1 bit wide. Those computers were necessarily very minimalistic because of the high cost of tubes, relays, and transistors at the time.
Good luck on your TTL CPU.
Many 8-bit CPU architectures have instructions that consist of more than one byte. I see no reason why a 1-bit CPU could not similarly have some instructions that consist of multiple bits.
At a more general level: The "bit-ness" of a CPU typically only reflects the size of its registers. It's perfectly possible (and, indeed, quite common) for instructions, the address bus, and/or even the data bus to be different widths from registers.
