What circuit topology should I use for digital high voltage (20v-30v) to low voltage (3.3v-5v) conversion (for MCU input) and vice-versa? I can think about the following topology:
  1. Voltage divider based
  2. Power MOSFET based switching with NMOS gate drive
Further to this question, what topology should I use for analog voltage and current input from high side (20-30v) to MCU side (3.3v-5v) for ADC input? I can think about the following topology:
  1. Non-inverting Op-amp amplifier
  2. Voltage controlled current amplifier
Reference: I wanted to integrate the solution into my existing embedded system and the particular product feature I am looking for can be referred from this link: http://www.phidgets.com/products.php?category=0&product_id=1012_2
  1. For digital signals - Voltage divider + zener
  2. For analog signals - Inverting OpAmp (a non inverting Op amp cannot attenuate) You can then "correct" the inversion by firmware or by SW, or you could use a voltage divider followed by a unity gain non inverting op amp.
  • \$\begingroup\$ 1. This is for digital input, what topology for digital output from low side to high side. \$\endgroup\$ Aug 29, 2016 at 6:42
  • \$\begingroup\$ 2. Analog - What about analog input current? Input side is having 0mA to 20mA current range. \$\endgroup\$ Aug 29, 2016 at 6:51
  • \$\begingroup\$ For an analog input current you can make a current to voltage converter using an op amp \$\endgroup\$ Aug 29, 2016 at 8:34
  • \$\begingroup\$ My circuit is supposed to switch faster and power efficient as well. I have a general understanding that voltage divider circuits always consume current and thus power dissipation happens. Further, for logic level conversion, most modern circuit designs are made up MOSFET+NMOS topology. Where to consider MOSFET in switching and voltage conversion application? \$\endgroup\$ Aug 29, 2016 at 12:03
What circuit topology should I use for digital high voltage (20v-30v) to low voltage (3.3v-5v) conversion (for MCU input) and vice-versa? I can think about the following topology: 1. Voltage divider based 2. Power MOSFET based switching with NMOS gate drive.
Voltage divider. It's very simple and requires no active components. If calibration is required a small trim-pot can be added. See Figure 1a.
For DAC output 0 - 30 V, a non-inverting opamp is required. See Figure 1b. Gain is \$ 1 + \frac{R_5}{R_6} \$. I have chosen supply voltages so that the opamp doesn't have to run rail to rail. You may decide otherwise.
Further to this question, what topology should I use for analog voltage and current input from high side (20-30v) to MCU side (3.3v-5v) for ADC input? Input side is having 0mA to 20mA current range.
For this you need a current to voltage converter - a resistor. See Figure 1c.
  • \$\begingroup\$ My circuit is supposed to switch faster and power efficient as well. I have a general understanding that voltage divider circuits always consume current and thus power dissipation happens. Further, for logic level conversion, most modern circuit designs are made up MOSFET+NMOS topology. Where to consider MOSFET in switching and voltage conversion application? \$\endgroup\$ Aug 29, 2016 at 10:48
  • \$\begingroup\$ Faster than what? What power loss have you calculated for the potential divider suggested? \$\endgroup\$
    – Transistor
    Aug 29, 2016 at 12:41
  • \$\begingroup\$ You are not doing logic level conversion. You specified analog. \$\endgroup\$
    – Transistor
    Aug 29, 2016 at 12:43
  • \$\begingroup\$ This last comment is particularly for digital input/output question. Particularly I am looking for a solution according to this device which is using NMOSFET: phidgets.com/products.php?category=0&product_id=1012_2 \$\endgroup\$ Aug 29, 2016 at 13:45
  • \$\begingroup\$ Sorry, but that's a new question. \$\endgroup\$
    – Transistor
    Aug 29, 2016 at 13:47
