I need to design light blinker which are mostly used on road side for indication purpose. Their main purpose is to blink with a rate of 500ms or 1sec. These type of circuits contains two PCBs, one is 555 timer circuit and another one is led circuit. Now I have studied about 555 timer and have calculated the values of resistance and capacitance required for 1sec blink. Following is the circuit for timer:
So I have used a R1=1K
R2=150K
C=10uF
. At the output pin I connected a led via 330ohms resistance and led was blinking with 1sec delay. Now I need to design the led circuit for blinker. Total leds will be around 170 and I need to control all the leds with this 555 circuit and blink them with 1sec. Now I am confused how to design this circuit. How to connect all the leds(parallely or in series) to avoid voltage drop. I will be using 5MM led with 330ohm resistor. I guess I need to connect them parallely to avoid voltage drop but I am not sure. Is there any other circuit I need to add to avoid voltage drop. Does anyone has already made such kind of circuits. Any help or reference guide please. Thanks
