8
It is used on a small board RFID antenna circuit based on the TMS3705:
At the first check it seems to be a 0 ohm resistor, but the dimension 4x4mm its strange.
Any ideas?
L.
It is a "zero ohm link".
You can find them listed in the resistors section of a vendor's parts catalog.
It is typically used to turn on or off configuration options on the circuit board. The "0" marking is intended to make this stand out among a group of actual resistors.
They come in many sizes and even through hole versions. It is possible that this one is large in order to make hand-soldering easier.
    \$\begingroup\$ The through-hole ones typically have a single black band, which helps them to stand out among a group of normal through hole resistors. \$\endgroup\$ – Wossname Sep 2 '16 at 9:29
9
It is a 0 ohm resistor. They probably planned to have an inductor there, but replaced it with the 0 ohm resistor during testing/production preparation. It might be replaced to reduce cost. Or they might have it as a way of correcting the impedance of the antenna if needed. You can of course measure it using a multi meter.
  • \$\begingroup\$ There's many more reasons to use 0R than just replacing inductivities; in fact, I've never seen that happen. \$\endgroup\$ – Marcus Müller Sep 2 '16 at 18:49
9
As others have said, it's a 0\$\Omega\$ resistor.
The reason why the unusual package is used is because they wish to minimize the inductance since it's in an RF circuit.
Here is a datasheet for resistors (including 0\$\Omega\$) in wide (side terminated) packages.
    \$\begingroup\$ As a side note, even though their 0 ohm value may imply 0W dissipation, these jumpers do have a max current rating (see table "Temperature coefficient and resistance range" on page 2 of the linked datasheet). Hence another rationale for big size in some designs (might not be the case here). \$\endgroup\$ – ghybs Sep 2 '16 at 17:52
