I have the following Xbee Shield where I need to constantly switch jumpers in order to allow Xbee communication and/or USB communication.
The following is set for Xbee communication:
Xbee Communication
"Xbee Communication"
The following is set for USB communication:
USB Communication
"USB Communication"
The following is without jumpers (which also acts as USB communication as well):
Without, also USB
"Without (also USB)"
As my Arduino and Xbee Shield are going to sit inside an enclosure with screws and my USB port being quickly available to plug a USB cord into I'd like to attach an ON/OFF switch that acts as XBEE/USB rather than have to unscrew it and manually shift the jumpers into the correct places. I'm not quire sure how to wire up a switch to do this.
Looking from a birds eye view. If the pins are as follows:
(1) (2) (3)
(4) (5) (6)
Considering that without any jumpers attached, it acts as USB communication. Am I then safe to assume that hooking up a switch like the following is going to be easy?
Switch
Any help is greatly appreciated.
Of course it's possible!
You just need a 3-pin switch that maps exactly the pins of the jumpers, and that commutes from the right to the left pin.
These are some examples...
Then, to connect it I would suggest to use a connector, so you can always come back to the jumpers way, but this way you usually can't disable both...there are also 3-positions switches that allow also to leave the contacts open.
UPDATE: I don't understand well the part with numbers; you need to keep the 2 jumpers separate, so you can use 2 switches and try to mechanically switch them simultaneously, or maybe you can find a switch that can simultaneously command 2 channels...
  • \$\begingroup\$ Grazie tanto! Can you see my updated question. I've added some reference numbers, which I'm not so sure of. \$\endgroup\$
    – gotnull
    Jan 24, 2012 at 9:30
  • \$\begingroup\$ @Fulvio Prego! But the part with numbers has confused me... \$\endgroup\$
    – clabacchio
    Jan 24, 2012 at 9:32
  • \$\begingroup\$ Let's say you're counting from top-left to bottom-right where the top-left is (1) and the bottom-right is (6). \$\endgroup\$
    – gotnull
    Jan 24, 2012 at 9:34
  • \$\begingroup\$ @Fulvio yes but what are you meaning with "the positive lead is attached to (1) (2) and the negative lead is attached to (4) (5)"? \$\endgroup\$
    – clabacchio
    Jan 24, 2012 at 9:35
  • \$\begingroup\$ I've added a photo of the switch I want to use. \$\endgroup\$
    – gotnull
    Jan 24, 2012 at 9:40
Something like this? It will connect either of the two Jumper settings but not do the no jumpers at all mode, if thats even neeeded. Totally use a connector.
