I have a led strip with its 24V own power supply (IKEA's Ledberg), and I want to make them dimmable. I've successfully done it with an arduino and a MOSFET, but I'm unsure if the power supply will deal with it correctly.
I know that some power supplies will monitor the output and try to provide a constant current, but I'm not sure about the Ledberg ones. Is there any way I can be sure?
  • \$\begingroup\$ (a) contact IKEA. (b) experiment and see for yourself. \$\endgroup\$ – Brian Drummond Sep 2 '16 at 22:34
    \$\begingroup\$ (a) IKEA will surely just say "you can't". (b) I don't have a problem experimenting. I already did. They dimmed correctly. But I don't know how to check if the power supply will get damaged, without leaving it on/dimmed for a long time (and still, I would not be sure). \$\endgroup\$ – amfcosta Sep 2 '16 at 22:36
  • \$\begingroup\$ Are the ledbergs holding up being dimmed? \$\endgroup\$ – Jason Li Mar 17 '17 at 5:21
  • \$\begingroup\$ @JasonLi I haven't done it yet. \$\endgroup\$ – amfcosta Mar 17 '17 at 10:20
