I designed single layer PCB in Altium Designer. Now I want to setup Drill Dot open in Soldering layer (bottom layer) to generate Gerber file for the manufacturing purpose. Can anyone help how to do this?
Here are the pictures (blue is my file, red is example for drill dot open).
If your board is drilled with a NC drill machine, these drill dots are not needed. If you want to drill the board manually, drill dots aid positioning.
It is possible in Gerber to use pads with drill dots, pads with holes do exist. But the problem is that all traces beginning or ending in a pad with a hole paint the hole. The traces should be modified not to end in the center of a pad.
It may be done in Gerber using the LPD and LPC commands. Switch to LPD, plot all pads and traces, switch to LPC and plot all drill holes as small round pads with the diameter of the hole. In this way positive and negative plots may be combined.
I can't tell how this may be done using Altium, but it is possible in a Gerber plot file.
This isn't normally done, because the dot will be drilled out anyway, so it doesn't matter -- however a slight misalignment, and the via will have a bad connection.
If you don't want a connection, use a non-plated through-hole, which will not generate any copper at all.
    \$\begingroup\$ Drill holes are not needed for NC drilling, but they are helpful for manual drilling of the PCB. A single layer PCB has no vias and needs no plated through holes. \$\endgroup\$
    – Uwe
    Sep 5, 2016 at 8:52
