Comes with the Arduino Uno
As you can see, it may require soldering. I don't have soldering experience but am receiving a soldering iron soon. Could you explain how this would need to be soldered if that's the case?
  • 7
    \$\begingroup\$ You don't fix these, you just buy more. \$\endgroup\$ – Matt Young Sep 5 '16 at 17:16
  • \$\begingroup\$ If you're using lots of these, it's not even worth it to buy new crimps to replace broken ones. It's more worth your time to have spares than to trim/strip/place/crimp a new connector pin. \$\endgroup\$ – user2943160 Sep 5 '16 at 18:45
6
You wouldnt. These are consumables that cost a fraction of a cent. You buy new ones for 20 or 50 for a dollar shipped.
The pin on that is formed metal that is crimped on, it is not soldered. You could try soldering the pin back on, but it will be a task in futility.
| improve this answer | |
solder is not as strong as original unless crimped for strain relief.
Just use 22-24AWG solid jumper wire from phone cable cut and stripped to many short lengths for neater breadboard and lower inductance.
  • \$\begingroup\$ That's a pretty tough wire.. Fortunately, I discovered Fry's today and I almost fainted–it's paradise for electronic components. So I bought 50 wires for 10 bucks. Thanks for the help guys! @Passerby \$\endgroup\$ – Roman Sep 6 '16 at 4:28
