It is well-known that any electrical passive element (Resistor, Capacitor,Inductor) contains parasitics that usually manifest themselves at high frequency ranges of operation.
For example, a resistor at DC can be modeled, simply, by just a resistance that depends on the material and geometry of the element. At higher frequencies, parasitic capacitance and inductance start to show up, and this can be experimentally found (for example) by:
  1. Voltage - Current phase difference.
  2. Impedance dependency on frequency.
The same argument is also valid for capacitors and inductors, in which their ideal model is altered and parasitic effects are added at high frequencies.
The plot of Impedance vs. frequency can tell us about these parasitics and when do they start to show up. They will also inform us about the valid frequency range of operation, in which after it, the element no longer behaves normally (An inductor acting as a capacitor after its self resonance frequency (SRF) for example) as shown below:
So when we mention the term "high frequencies", we (probably?) mean beyond the SRF, as elements start behaving as unintended.
Up to my understanding, every passive element generally behaves in a way that I thought of explaining by the figure below:
My questions are somehow interconnected and they are:
  1. Is the concept of figure (2) correct?
  2. In addition to the parasitics that were mentioned above, there seem to be variations in the physical values of L, C, and R themselves (Blue region in figure 2), meaning they all become functions of frequency: R(w), C(w), L(w). Is this true?
I concluded this from:
a. Skin effect for R, making it a function of frequency.
b. Picture #1 above (blue graph). Does the inductance really become negative, or is it the tool we are using that is telling me my inductor value was lost due to the large parasitic capacitance value?
  1. How does the geometrical feature size of the passive element (regardless of its shape) plays a role in determining the frequency separating the green and the blue regions in figure (2)? In other words, is there a way to determine if I have to consider AC effects or not using the knowledge of my feature size?
  2. Can we say line separating the blue and red regions can be represented by the SRF?
    \$\begingroup\$ High frequencies aren't the only regime of nonideal behavior. For example, some capacitors have soakage effects that mainly affect the behavior at very low frequencies. \$\endgroup\$
    – The Photon
    Sep 5, 2016 at 21:28
  • \$\begingroup\$ EMI/EMC covers a broad territory. The pathology of slots, gaps and skinny traces all have reactance and wavelengths and insulators of any type are also capacitors depending on gap between conductors. Can you be more specific about physical to electromagnetic examples? \$\endgroup\$ Sep 1, 2021 at 13:16
1/2) More or less, I try to clarify, It seems to me you believe your graph in figure (2) shows R and L variations w.r.t frequency.
That graph simply shows impedance of a parallel resonant circuit made of approx constant 100nH inductor, 45kohm resistor and a \$\frac{1}{(2\pi\times 2\,\text{GHz})^2\times 100\,\text{nH}}\approx 65\,\text{fF}\$ capacitor.
This is one first level approximation which may however be good in many circumstances.
Then one can argue resistance is frequency dependant and add this to the model, the same for inductance and capacitance but this can usually hardly be seen on graphs unless you carefully measure, analize and fit curves to models.They are ususally hidden in measurements errors.
Then you can add many other extra parasitics and non linerities outlined above by other contributors, but there's no such an evidence in the sweep you posted.
b) Your meter shows variable (possibly negative) inductance just becouse you ask it to do so. It just measures an impedance, one complex ratio between voltage and current and then represent it as you configured it to do: you asked for Ls+Rs and if measured impedance phase does not agree with that model it just keep computing and findes "negative inductances".
Usabilty boundary (green/blue transition in fig. (2)) is not function of your component parasitic only, but it depends pretty much on the rest of the circuit e.g. if using that inductor in a resonator you should add stray capacitance to the computations and see if you get consisten numbers.
4) Yes SRF is that blue to red boundary.
3) Dimension do count. For resistors and capacitors usually the longer the part the higher the stray inductance. E.g. small SMD 0204 or 0603 may exhibit a few hundred pH while some big HV MKM capacitors I happened to use were specified as 7nH/cm w.r.t to terminals pitch.
**YES, negative (-j) inductance means capacitance at high f after PRF. Negative capacitance (j) from series metal about <1 nH/mm is inductive after SRF.
Ceramic is also a crystal with SRF and may have a PRF in special cases especially when parallel caps are used, together as in MLCC or on PCB , except for NP0/C0G types.**
Impedance Testing with a Network Analyzer can measure these if they are problems.
It is not exactly as shown or as you assume. It is also not possible to have a universal model for all passive components. enter image description here L&C will have series R and parallel C,
C will have series R,L and parallel R, and sometimes more parts in the model
Components may have a series and parallel resonant frequency and many other variables for Vdc, T('C), I(L) with saturation.
It is possible to use caps above "series resonant freq", SRF but it is often useful to have inductors near or above "parallel resonant frequency", PRF unless to add another in series with higher PRF.
( Sometimes specs use SRF for both modes as self res. freq.)
When your operating frequency is in the range of the SRF, it is necessary to either choose a different part with higher SRF, or an "additional" part to provide the desired impedance (extra smaller L in series or smaller C in //)
Suggested reading http://www.johansontechnology.com/srf-prf-for-rf-capacitors
  • RF Engineers understand the L/W ratios that control the inductance or ESL of Caps and stripline. SRF actually refers to the Series Resonant Frequency of capacitors, which also have an anti-resonance (PRF or parallel res.freq.) by slightly raising the ESR by a controlled amount to reduce these effects and EXTEND the "USEFUL" range of low impedance to the right in the frequency axis. i.e. useful above SRF enter image description here
  • Inductors have a Parallel Resonant Frequency, while Caps have both a SRF and a PRF since they do not have the Cs cap.
  • Resonators like MEMS and quartz use the same model above but have massive inductance for their size and tiny <<1pF series capacitance so their PRF comes first followed by the SRF.
  • \$\begingroup\$ A design that depends on SRF may be risky. Many manufacturers give you "typical" SRF, but don't specify tolerances or a measurement method. You also run the risk of not finding a substitute that behaves similarly. \$\endgroup\$
    – glen_geek
    Oct 6, 2016 at 1:59
  • \$\begingroup\$ To be complete with your model in picture shown, one "must" add the capacitors, on every side of the component, to ground. Ok, these can be "low", but in some circumstances, they must be taken into account (when a shield is used for inductor, for example). \$\endgroup\$
    – Antonio51
    Sep 1, 2021 at 9:21
  • \$\begingroup\$ @glen_geek I was only referring to Murata's special anti-resonant capacitors which are dampened and use wide geometry. No subs except perhaps Johanson. \$\endgroup\$ Sep 1, 2021 at 10:01
  • \$\begingroup\$ @antonio good point to add the Pi or CLC filter concept \$\endgroup\$ Sep 1, 2021 at 10:03
  • \$\begingroup\$ @Tony Stewart EE75 Would it be of interrest ... adding the complete schematic of a true "homemade" Q-meter in the range 1kHz-25 MHz or more ? Some "calculation" would be done and added with explanations for measuring many "components" (R-l-c, L-r-c, C-l-r, very low or very high impedances, permittivity and so on ... ) and I don't want make it all alone ... \$\endgroup\$
    – Antonio51
    Sep 1, 2021 at 10:43
