-1
There is a simple switching sensor which will be wired to a circuit by a BNC cable as shown in the above illustration.
As you see, when the switch is ON the potential at the point "A" will be high; and when the switch is OFF the potential will be zero. Pulse freq will vary from 1Hz to 40Hz.
For some reasons, I need this ON-OFF pulse output to be sharp and clean. So I want to take the point "A" as an input to a circuitry(Schmitt trigger) and obtain a better output.
I need advice when designing a Schmitt trigger circuit which satisfies the following expectations for the output pulse:
It shouldn't bounce, it should be immune to noise and it should be as sharp as possible(very short rising falling edges). And it should work for 5V to 12V Vcc range.
I would appreciate any generic circuit or idea.
  • \$\begingroup\$ Nothing is ever immune to noise. Also, just do some classic debouncing and whack a schmitt trigger IC after it, not sure what the big deal here is. \$\endgroup\$ – PlasmaHH Sep 6 '16 at 10:07
  • \$\begingroup\$ a known design would help \$\endgroup\$ – user16307 Sep 6 '16 at 10:09
Something like this?
R1/R2 and R3/R4 are the voltage dividers to set trigger offset and hysteresis, R5/C1 is the input low-pass for debouncing (\$f_c = \frac{1}{2 \pi R C}\$). Output is inverted, obviously.
I used V3 to model bouncing and to test the low-pass, you might want to use different resistor/cap values.
  • \$\begingroup\$ Thanks. Does V2 correspond to the input "A" in my illustration? Is it ok for 5 to 12Vcc supply range as well with the same values? \$\endgroup\$ – user16307 Sep 6 '16 at 11:45
  • \$\begingroup\$ and can I use LM2903 instead? Is TL081 better? \$\endgroup\$ – user16307 Sep 6 '16 at 11:47
  • \$\begingroup\$ Im having 1.8V offset at the output low in LTspice simulation. How make low around 0V? \$\endgroup\$ – user16307 Sep 6 '16 at 12:13
  • \$\begingroup\$ V2+V3 correspond to your input A. Please consider that your "pull-up" must be a magnitude bigger than 330 Ohms, or your switch will not pull A down enough. I didn't choose an OpAmp, that's up to you. If you need 0V low, you need an OpAmp that can handle rail-to-rail voltage, the LM2903 should probably do (~400mV). \$\endgroup\$ – michi7x7 Sep 6 '16 at 12:17
  • \$\begingroup\$ thanks I opened a new question hope u might have an input: electronics.stackexchange.com/questions/256554/… \$\endgroup\$ – user16307 Sep 7 '16 at 12:17
