I'm trying to get the internal RTCC working but it doesn't seem to work.
What I'm using-
  • MikroC pro for PIC
  • using internal 8mhz clock(INTOSCPLL)
  • Using INTRC as a clock source for RTCC
and using the following code:
 void main() {
 char txt[7];
 //Setup RTC
 T1CON.T1OSCEN = 1;
 delay_ms(50);
 RTCCFG.RTCWREN = 1;
 PADCFG1.RTSECSEL1 = 1;
 PADCFG1.RTSECSEL0 = 0;
 RTCCFG.RTCEN = 1;
 RTCCFG.RTCPTR1 = 0;
 RTCCFG.RTCPTR0 = 0;
 //Set analog ports as Digital
 ANCON0 = 0x1F;
 ANCON1 = 0x1F;
 I2C1_Init(400000);
 Oled_Init();
 Oled_FillScreen(0x00);
 while(1){
    IntToStr(RTCVALH, txt);
    Oled_Text(txt,0,2);
    IntToStr(RTCVALL, txt);
    Oled_Text(txt,0,4);
    delay_mS(1000);
The RTCVALH and RTCVALL should display minutes and seconds. But their values don't change at all. They show constant values of 56 and 50.
What steps am I missing?
I believe you need to set RTCCFG.RTCWREN = 0; after you have finished writing to it. The datasheet mentions it under section 17.2.7 WRITE LOCK
| improve this answer | |
Make sure your configuration bits for setting the RTC clocking source are correct. The bits responsible for is the RTCOSC bit in the the CONFIG3L.
EDIT: RTCWREN can't simply be set to one. You should follow the sequence mentioned in the datasheet
    \$\begingroup\$ Thanks for you answer but if you read the question properly, you'll notice that I've mentioned Using INTRC as a clock source for RTCC which is set on CONFIG3L. \$\endgroup\$ – Suraj Bhawal Sep 7 '16 at 11:47
  • \$\begingroup\$ Please check the editted answer \$\endgroup\$ – Latchup Sep 7 '16 at 22:26
