My PowerShot A720 IS digital camera (from 2008) permits AA-size 1.2 V NiMH or regular disposable AA alkaline batteries. Can I use AA-size 1.5 V Lithium batteries?
The manual (pdf) warns against nickel-cadmium, but doesn't mention Lithium:
This camera uses AA-size alkaline batteries or Canon AA-size NiMH batteries. While it is possible to use a size nickel-cadmium batteries, performance is unreliable and their use is not recommended.
Thoughts?
EDIT: Here are the proposed Lithium batteries.
closed as off-topic by Ignacio Vazquez-Abrams, Daniel Grillo, Voltage Spike, duskwuff, PeterJ Sep 11 '16 at 14:03
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Ignacio Vazquez-Abrams, Daniel Grillo, Voltage Spike, duskwuff, PeterJ
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Primary Lithium cells, rather than rechargable? \$\endgroup\$ – Sean Houlihane Sep 9 '16 at 17:34
I've been using 1.5 volt AA lithium cells in my Nikon camera for some time with no problems. As long as the voltage is correct, I don't see any reason not to use them.
  • \$\begingroup\$ Interesting. I was curious about AA lithium, but had never used them before. Looking at this datasheet: varta-microbattery.com/applications/mb_data/documents/… , I find that they seem to be rated for \$1mA-10mA\$ loads, which is quite different from what alkaline and NiMH batteries support. \$\endgroup\$ – jonk Sep 9 '16 at 17:47
  • \$\begingroup\$ @jonk - Hi - FYI the battery you have linked is not a normal AA battery; it states "Nominal Voltage ... 3V" so it is different to what Peter Bennett is talking about. \$\endgroup\$ – SamGibson Sep 9 '16 at 17:52
  • \$\begingroup\$ @SamGibson: Thanks. I had just noticed that! I need to look at the right datasheets! \$\endgroup\$ – jonk Sep 9 '16 at 17:53
Canon's comment about the reliability of NiCd seems to be voltage related because NiCd has about half the output resistance of NiMH so I would think they are superior for high-current flash-type discharges and optical zoom motors.
Under that assumption your 1.5V Lithium cells would be fine.
    \$\begingroup\$ LiIon -> Lithium. quite different beasts. \$\endgroup\$ – Russell McMahon Sep 10 '16 at 15:46
