I just moved from KiCAD to Altium. For some reasons the schematic I was able to put on the single sheet in KiCAD spreaded into 4-5 sheets in Altium.
However this can be useful as I can put functional blocks into different sheets making the schematic more readable.
So what I intend is to have one PCB and several schematic sheets. Connections between sheets should be done via ports (Place -> Port
However as I tried to transfer components and the netlist into PCB and I saw the window telling me that only one schematic sheet will be updated (while I have 4):
As I know I should make a top-level schematic sheet with a blocks representing the low-level schematic sheets (hierarchical schematic). It can be very useful for a big projects but for now (remember, I could put all schematic on the single A4 schematic sheet in KiCAD?) I'd prefer something easier.
In a tutorial video was mentioned that there is a "flat design" way. But I wasn't able to find any info how to implement this.
Actually I'd like to have only several sheets with no top level. Is it possible?
