I have 97 LEDs soldered on to a stripboard in rows. Each row has varying lengths and I have no idea how to power the whole sign at once.
I tried powering 28 LEDs across two rows using a 9 volts (I was going to use a 9V battery but the bench power supply seemed more forgiving if I do something wrong) on a bench power supply connected to a buck converter. When I powered the circuit, the LM2596 chip on the buck converter went bang!
I was able to use this set up to power short strings on 4 LEDs but I would like to power the whole thing at once.
How would I power this board? Should I be using a buck converter, should I use something else and is there any way to power the all the LEDs with a battery.
I was trying to follow a tutorial on YouTube (The tutorial by Great Scott I tried following) but didn't know how to connect the LEDs
Below is a picture of the setup of the Buck converter enter image description here
Below is a rough diagram of what i was going to make (Black thick line being LED string and Red thin being wire connecting strings) enter image description here
I used this Buck converter module https://www.amazon.com/gp/product/B008BHB4L8/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B008BHB4L8&linkCode=as2&tag=gre09a-20&linkId=4YLLYWHFS3V7EXZM
  • 4
    \$\begingroup\$ I don't see any resistors or current control in that circuit. For 97 LEDs you'll need almost 2A of current, and it won't work if you have mixed colors. This many LEDs in parallel with no ballast resistors is asking for trouble. Basically you've effed this one up :( \$\endgroup\$
    – Daniel
    Sep 13, 2016 at 21:36
    \$\begingroup\$ Oh dear oh dear oh dear. I'll bet he posts on Instructables too doesn't he? Throw away your electronics, and take up farming instead. You'll have more success than following people like that who haven't got the slightest clue what they are doing. \$\endgroup\$
    – Majenko
    \$\begingroup\$ @Majenko Yeah I've found his tutorials useful for ideas but not for learning he goes far too fast and never explains why somthing is done \$\endgroup\$
    – bob1252
    Sep 13, 2016 at 21:39
    \$\begingroup\$ OMG you're not kidding... that's actually what he says in the video! Well, driving a bunch of parallel LEDs from a voltage supply doesn't work. As they say "Christ, what an Asshole!" (re: GreatScott) \$\endgroup\$
    – Daniel
    \$\begingroup\$ @bob1252 He doesn't explain anything because he doesn't know anything. He has half knowledge, and in electronics half knowledge can be very dangerous. And worse than that, he's spreading half knowledge and misinformation around, so more people think they know what to do and blatantly don't. These kind of tutorials (and Instructables is full of them) are terrible. Never use them. \$\endgroup\$
    – Majenko
    Sep 13, 2016 at 21:41
The entire approach spouted in that video is complete nonsense and you should ignore it completely.
You should instead completely change how your circuit works. Run it from a higher voltage (9V is fine, 12V may be easier), and arrange the LEDs in chains of series LEDs with the sum of the forward voltages in each chain totalling less than (but close to) the supply voltage. Then add a suitable resistor to each chain to set the forward current.
$$ R = \frac{V_S - V_{F(T)}}{I_F} $$
\$V_S\$ is the supply voltage, \$V_{F(T)}\$ is the total forward voltage of the LEDs in the chain, and \$I\$ is the current the LEDs need (20mA, for example).
Alternatively, to reduce the power consumption, you can drive them as a matrix so that only a few of them are on at once. That means more complex circuitry though and typically a microcontroller to control it all. It does mean you can do animations though.
For the curious, this is a frame from the video in question. You can plainly see how by placing the LEDs in parallel like he advocates some of the LEDs are brighter than others. Those ones have a fractionally lower forward voltage than the dimmer ones. As a result more current flows through them and they are brighter. The others don't get as much current, so they are dimmer.
The supply voltage has to lie at a specific point on the I-V curve to limit the current. Any slight variance in the voltage away from that point and the current rises sharply resulting in destroyed LEDs and smoke from the power supply.
In order to use the method he advocates with any measure of success you need to have all your LEDs from the same batch with the forward voltage as near to perfectly matched as possible. Hard to do, unless you are working hand in hand with an LED manufacturer that can create accurate batches for you. So much easier to just split it as I show above.
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Dave Tweed
    Sep 18, 2016 at 1:39
  • \$\begingroup\$ I just scaled it down to 20-30 LEDs and it works \$\endgroup\$
    – bob1252
    Sep 22, 2016 at 21:23
Connecting LED strings in parallel will NOT work. I do not care if you use LED binned by forward voltage, parallel will NOT work with large strings. 3 LEDs in the string more likely.
To do things correctly, you need a current driver for each string.
Parallel strings is a kludge.
Use 96 LEDs not 97.
You cannot use a buck regulator when the input voltage is less than the forward voltage of the string.
The buck regulator you chose requires the input to be 5v higher than the output.
The max input is 40V and max out is 35v. With a buck, the input must be greater than the out. The output voltage is determined by the number of LEDs. Approx 3.2v x # of LEDs.
With 9V in you can power 2 or 3 LEDs. Red LEDs have a lower forward voltage and so 9v could power 3.
You use a boost regulator if input voltage is lower than the string's forward voltage.
You should use a multi-channel common anode LED driver .
Use at least 6 strings of LEDs to keep the output voltage down.
A battery powered linear regulator is very simple if you do not need PWM dimming.
My preference for powering LEDs is 48VDC. You can easily drive strings of 16 LEDs with a simple buck regulator.
Going over 48v you can get in to electrical code issues.
The higher the voltage, the more efficient the regulator.
For efficiency keep the string's forward voltage close to (but must be below) the input voltage.
Choose a regulator with a minimal cutoff voltage and a power supply with an adjustable output. The you can tweak the supply to a circuit efficiency of 95-98%.
I would use something like two of the 4 channel Integrated Silicon Solution Inc IS31LT3117 $1-$2 each.
Very simple circuit, almost everything is built into the chip.
Two 16 pin ICs, 4 caps, 2 resistors and 8 channels.
The voltage cutoff (headroom delta between Vin and Vout is only 0.8)
Use 96 LEDs in 8 channels of 12.
Measure the forward voltage of your strings and use a power supply 1V more than the string with the highest forward voltage.
IS31LT3117
4-channel, linear regulated, constant current LED driver which can provide 4 equal currents outputs of up to 350mA per channel to drive high brightness LEDs over an input voltage range of 6V to 53V
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
