[Adding followups to the bottom of the question]
  • Compare sample rates from logic probe.
  • Faulty breadboard (2 address bus pins not connecting); rebuilding on protoboard with short bus wires soldered in.
  • Moved to a perma-proto (soldered) test harness with a DIP24 IC socket, but still address line issues; Cleaned EPROM pins, and address lines are good.
  • Verified data signal is now clean!
I've pulled an Intel M2716 16K (2K x 8) UV Eraseable PROM from an old ECU, and plugged it into a breadboard, connected the address and data bus to a Teensy 3.2, and probed the data bus with a Saleae Logic Pro8.
At the heart of the ECU is an Intel MCS-48 Micro (P80A48H), that is using this 2716 EPROM for all of it's PROGMEM addresses (External Access pin is permanently driven high).
breadboard schematic
Like the ECU it came out of, I wired the Chip Enable pin to GND and the programming rail VPP at VCC (5V). However the Output Enable is controlled by the Teensy with a digital output pin. Pulling it down 10us before starting a device read, and back up after the address range has been read. Note that this EPROM is static, and does not require any clock input.
Using GPIO ports in the Teensy code, I write the address bus, wait a little while, and read the data bus. The bytes fill up an array, and then I dump that back to the Serial console..
EPROM Read Delay = 5
Read from 0x0000 to 0x7FF
0x0000:  E5 24 40 99 FE 04 37 D5 AA B9 20 11 F1 03 DE F6 2D B9 3E F1 C6 1A 07 A1 04 24 B9 3C F1 A9 C6 22
0x0020:  E5 24 40 99 FE 04 37 D5 AA B9 20 11 F1 03 DE F6 2D B9 3E F1 C6 1A 07 A1 04 24 B9 3C F1 A9 C6 22
0x0040:  E5 24 40 99 FE 04 37 D5 AA B9 20 11 F1 03 DE F6 2D B9 3E F1 C6 1A 07 A1 04 24 B9 3C F1 A9 C6 22
0x0060:  E5 24 40 99 FE 04 37 D5 AA B9 20 11 F1 03 DE F6 2D B9 3E F1 C6 1A 07 A1 04 24 16 3C F1 A9 C6 22
0x0080:  F2 89 FE 77 77 43 C0 04 98 FE F2 93 03 FB E6 67 FE 04 98 53 7F 77 43 80 B8 23 AC A0 BD 01 BE 02
0x00A0:  F2 89 FE 77 77 43 C0 04 98 FE F2 93 03 FB E6 67 03 00 F6 19 BD 07 B2 06 B8 22 BB 00 00 60 00 C1
0x00C0:  1B ED BD 2B 67 EE C3 A0 89 01 B8 21 F0 37 12 E5 B8 24 95 B6 D7 B0 05 F0 C6 DE 07 A0 24 11 B8 25
0x00E0:  1B ED BD 2B 67 EE C3 A0 89 01 B8 21 F0 37 12 E5 37 17 62 19 A1 24 00 00 00 00 00 00 00 00 00 00
0x0100:  C8 03 FF 27 70 07 F2 0C 19 A1 99 CF B8 20 B0 00 55 A5 B5 B8 35 F0 C6 1A 07 A0 B8 2A F0 03 FF F6
0x0760:  95 95 95 95 95 95 95 95 6C 65 5F 5C 5A 59 5D 65 07 10 14 1C 28 15 25 14 23 34 34 50 53 61 76 77
0x0780:  25 30 44 57 69 77 82 8C 98 A6 A6 A3 A5 A5 A5 A5 8B AB BA C0 84 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0
0x07A0:  75 94 00 B3 80 BB BB BB BB 80 B3 BB 00 81 80 81 CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA
0x07C0:  75 94 A8 B3 BE BB BB BB BB BB BB BB BB BB BB BB 8B AB BA C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0
0x07E0:  90 94 88 80 80 C5 C5 C5 C5 C5 C5 C5 C5 C5 C5 C5 CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA 00
So far, so good.
But the results were not consistent. Repeating the device read, and comparing the "dump" output in a text editor, I can see some bytes are different between reads :(
I probed the address bus to confirm that address lines are stable before trying to read the data bus.
TODO: show address line waveform
Switching over to the data bus, I sacrifice one data bus bit for the Output Enable line, and inspect the analog samples from the probe..
data start
To my untrained eye, it looks pretty reasonable, and the Teensy is fine with the logic levels being driven by the M2716 at ~ 4v. It's 5V tolerant, but 3v3 natively.
Output Enable is on D7, and the timing markers show my 10us delay between enabling outputs, and writing the first address to PORTC.
void readUntil(uint16_t maxAddr) {
    enableEprom();
    delayMicroseconds(10);
    noInterrupts();
    while (addr < maxAddr) {
        contents[addr] = readEprom(addr);
        addr += 1;
    interrupts();
    disableEprom();
uint8_t readEprom(uint16_t a) {
    // Write direct to port
    GPIOC_PDOR = (uint32_t)a;
    // Take a small delay for the address line to take effect in the ROM
    // ~450ns for data to appear on the bus (verfied on logic analyser)
    delayMicroseconds(5);
    return (uint8_t) (GPIOD_PDIR & 0xFF);
But looking further along the capture, I find wonky logic levels coming out of the M2716..
data wonky
Hmmm. What is that level supposed to be?
The data sheet has this to say about High/Low voltage levels:
That wonky voltage level is occurring in the same addresses each time I read. I haven't checked all of them on every read, but spot checking, they appear to be consistent.
So, the big questions are:
Is this EPROM faulty or failing?
  • The ECU it came from was swapped for another unit because of hard-to-diagnose problems with the running of the engine.
  • Perhaps this is just what old-skool TTL levels look like on a scope?
  • Or maybe these are "unused" addresses and were never programmed originally??
Can I do something better with my test harness to improve the logic waveforms from those addresses?
  • Pullup/Pulldown resistors?
  • Slowing down the read didn't change anything
  • Power supply is adequate (DC-DC converter at 5.0V)
  • Toggling Output-Enable between address-write and data-read didn't clean it up
Should I adhere to the data-sheet VOH=2.4v and consider that the exact cut-off? - If so, how can I ensure the Teensy is using that as a logic-high threshold?
I'm about to go hunting for the pattern of what addresses these waveforms show up, but first I captured fewer channels so I could crank up the analog sample rate. I still need to go out to the garage and hook up a scope for an even better look, but this is a good start..
Bottom capture is 12.5MS/s, Top is 50MS/s. I framed the screenshot at exactly the same offset from trigger, and adjusted until the time axes match.
Is there something this can tell us about the EPROM cells in that location? Or the circuit that brings them out to the data bus pins?
Fixed
After moving from breadboard to IC socket perma-proto (soldered) board, I still had address bus problems. One or two lines were floating :(
Carefully cleaned the EPROM pins, and verified all address lines in good shape.
Switched probe over to data bus, and it's working well :)
Clean Signal
Ultimately a floating address line cause this unstable output waveform.
Lessons learned:
  • double check all 11 address lines, even if you only have 8 channels in your logic probe!
  • even a little bit of 35 year old flux on a pin can insulate it from a breadboard or IC socket
    \$\begingroup\$ Where is the decoupling? \$\endgroup\$ Sep 13, 2016 at 23:18
    \$\begingroup\$ Unprogrammed floating gate cells should read as solid 1s so that's not it -- nor is it "normal" I suspect. I'd hang a few 100nF ceramics off of the 2716s Vdd and Vpp lines, and see if the behavior changes; if it doesn't, I'd take some more measurements. \$\endgroup\$ Sep 13, 2016 at 23:50
    \$\begingroup\$ May be worth repeating the experiment with the 5V supply set to 4.9 and 5.1V. If it's marginal (losing charge from some of the programmed cells) it may still be able to generate good logic levels at a slightly different supply voltage. Or temperature - got freezer spray? \$\endgroup\$
    – user16324
    Sep 14, 2016 at 0:08
    \$\begingroup\$ @ThreePhaseEel, I've added a .1uF ceramic to the VCC of 2716. While taking a closer look at the supply rails, I noticed my use of PWM for RGB Led control was giving a little pulse on the rails every 2ms. Turned that off, and am still seeing the odd EPROM data bus signal (per update in question) \$\endgroup\$
    – ohhorob
    Sep 14, 2016 at 2:50
    \$\begingroup\$ Get everything else out of the way. Slow the whole process down and make sure you are taking time where you think you are. Park the address lines at a value of concern and read the data lines one by one with a voltmeter. Ever see the plans for programming/reading one of these manually with toggle switches? Think of using your Teensy as a more convenient version of that to debug. If it works slowly/paused but fails when sped up you know in what directions to look. \$\endgroup\$ Sep 14, 2016 at 6:24
I'll do my best to address the various sub-questions:
Perhaps. There is certainly abnormal behaviour, based on those Salae analog port traces. However I have never been very comfortable about the limited resolution of that feature (it's better than nothing, but nowhere near as good as a real scope, imho).
Absolutely not. For such a simple circuit, with equal loading on all data lines, the Voh and Vol levels should be near-identical for every read.
No, that doesn't explain it either - unprogrammed bytes read as 0xFF, with the same Voh and Vol levels as any other byte.
The only obvious thing from the schematic has already been mentioned in comments, and that's decoupling. However based on the limited analog traces so far, the observed abnormality doesn't match my expectation for insufficient decoupling. So I'm not hopeful that adding decoupling will help, but this absolutely much be added near the EPROM (I believe the Teensy has its own decoupling already on its little PCB).
I would focus on getting a minimal test case now. Find a "problematic" address, where data read from that address has abnormal logic levels (which translates to apparently different values read by the Teensy). Confirm that this is consistent behaviour for that address. Then check other "related" addresses e.g. 0x1 away. Then 0x2 away; 0x4 away, 0x8 away etc. In essence, looking for whether all addresses xx2x are affected, for example, or all addresses xx4x etc. Find the pattern! That will help to refine where you search for the cause.
[Added: Another possible pattern you might find, is that the affected data values have something in common; not the addresses. For example, when EEPROM D6 should be logic high, it might only have a low Voh (e.g. that 1.716V value shown on one of your screenshots) when D5 is logic low. So the pattern might not be related to addresses, but to data values. That doesn't change my recommendation to find the pattern of affected data - just don't assume that the pattern will be related to addresses, as it might be related to data values.]
I would also be using a 'scope, in conjunction with the logic analyser, to see details on the abnormal waveform which may not be apparent on the limited resolution of the analog pin of that analyser.
  • \$\begingroup\$ Thank you Sam. The logic probe is pretty detailed when I zoom in. What parts of the waveform are most useful to look more closely? \$\endgroup\$
    – ohhorob
    Sep 14, 2016 at 0:56
  • \$\begingroup\$ @ohhorob - Hi - I don't know what the limited resolution of the analog probe might be hiding until it has been compared with a decent 'scope. I've been surprised too often in situations like this, to guess what specific info we might see in this specific case. No amount of zooming-in on the existing trace will convince me that we definitely aren't missing something useful! Having said that, for example, on the "wonky levels" traces, what are those "dips & spikes" between bits which should be the same level? However imho none of that would explain the very low Voh - it's just another puzzle. \$\endgroup\$
    – SamGibson
    Sep 14, 2016 at 1:12
  • \$\begingroup\$ [continued] A photo of the hardware (to show the length and route of the data & address busses between EPROM & Teensy) would be interesting. However, I would still be focussing on finding the pattern of the read data (e.g. data values or data addresses?) to find which ones show the low Voh (and/or raised Vol). Questions: (a) In your "wonky levels" image, showing 3 signals - which data bits are they (D0-D7)? (b) Are the abnormal logic levels always seen only on those 3 data lines, or on others too? (c) Do you have any other 2716 EPROM available for comparison? I've just noticed something. \$\endgroup\$
    – SamGibson
    Sep 14, 2016 at 1:26
  • \$\begingroup\$ followed up on your suggestion for more detail in the wonky outputs. Added another capture with high sample rate for a closer look. There's a lot of oscillation going on!! \$\endgroup\$
    – ohhorob
    Sep 14, 2016 at 2:47
    \$\begingroup\$ I believe it was due to two address lines floating.. although it's interesting that some addresses were stable, and only a few were so wobbly. \$\endgroup\$
    – ohhorob
    Sep 15, 2016 at 4:24
