Image of the problem (I need to calculate the overall power for these 4 elements):
My main problem is that I'm unsure whether I can add cosfi1 + cosfi2=cosfi. I calculated them both, one for RC and the second for RL.
Here is my overall (exhaustive) attempt on this problem (please correct if you think something is wrong). Data given: $$R_1=20\Omega;R_2=3\Omega;L=12.73*10^{-3}H;C=212.2*10^{-6} F; f=50Hz, U_{R1}=40V$$
Solution: $$X_L=2\pi fL=4\Omega$$ $$X_C=(2\pi fC)^{-1}=15\Omega$$ $$Z_1=\sqrt {R_1^2+X_C^2}=25\Omega$$ $$Z_2=\sqrt {R_1^2+X_L^2}=5\Omega$$ $$I_1=\frac{U_{R1}}{R_1}=2A$$ $$cos_1\phi=\frac{R_1}{Z_1}=0.8$$ $$cos_2\phi=\frac{R_2}{Z_2}=0.6$$ $$U_{XC}=I1*X_C=30V$$ $$U_1=\sqrt {U_{R1}^2+U_{XC}^2}=50V$$ $$U_1=U_2=50V \quad (see \quad image)$$
$$I_2=\frac{U_2}{R_2+X_L}=7.14$$
And now calculating total I with total U being 50V
$$I=\sqrt {I_1^2+I_2^2}=7.41A $$ $$ P=U*I*(cos_1\phi+cos_2\phi)= 50*7.14*(0.8+0.6)=499.8W$$
I get 500 W, which is not listed in the results. Can anyone pinpoint my error?
EDIT: Tnx to Spehro Pefhany (answer below) I've found my answer: $$I_2=\frac{U}{Z_2}=\frac{50}{5}=10A$$ $$P_1=I^2*R_1=4*20=80W$$ $$P_2=I^2*R_2=100*3=300W$$
