I want to make a buffer which can drive my sine wave with an amplitude of ±25 volts and a frequency of 25 MHz. Which Op amp in LTspice should i use?
1 Answer
Use the one called opamp
. Make sure to follow the advice in the description to add a .LIB opamp.sub
statement:
The default bandwidth is too low, so you have to right-click on the opamp symbol and increase it. Set it to whatever you want. Here I used 1000 Meg:
\$\begingroup\$ hey! thank you so much :) but i need a real op AMP :( because i need to use it in my board... I found the THS3001 from ti and i think it should work \$\endgroup\$– Momo ThCommented Sep 19, 2016 at 13:02
pipe
's answer will do (or aG+C
withRpar
specified). Of course, for simple enough schematics, a VCVS will do, no need for useless complications. \$\endgroup\$
