I like the aesthetic of clear acrylic mounting of PCBs and I want to use it for a project I'm working on. For example as seen in the Mighty Ohm Geiger Counter,
Is esd something I should worry about? The project like the Geiger counter above will be handheld for use.
Also somewhat related, is it safe to use plain old rubber foam as padding with regards to esd (where the rubber foam would be in direct contact with traces and maybe some components on the PCB)? And what about as a substitute for rubber bumpers?
